Ideally keep the spacer thickness as small as possible in order to achieve clearance between rear tyre inner sidewall and radius arm.
Similarly, on the front the tyre inside edge should be just enough to clear the inner wheel arch on full lock. The Sportspack cars actually had lockstops to prevent tyres hitting the inner wing. I have used 1 cm as the desired clearance between tyre inner wall and radius arm on the rear. On the front a clearance of 2 cm is about ideal.
Wheel arch extensions are intended to allow the correct fitting of selected wheels/tyres without the wheels projecting beyond the bodywork. In fact, the width of the arch extension should be chosen to suit the wheels/tyres, not the other way around.
Doing this keeps the steering geometry as good as it can be with very wide wheels, remembering that the steering is actually designed for 3.5" wide wheels with 145 section width tyres.
