Has anyone fitted a top engine steady bar to the radiator side of a hydro suspension mk1/2/3 ?
If so, which one fits and doesn't get in the way of the hydro pipe?
Posted 20 January 2021 - 10:52 AM
Posted 20 January 2021 - 11:51 AM
Not looked at hydro car for a long time. Where does the pipe run?
Posted 20 January 2021 - 12:04 PM
I guess you are concerned about the connection to the plate. You should have no problems with the DSN Retrosport one.
and the arm can be very easily swung of of the way.
all the others are a right pain in the butt to move out of the way.
https://www.dsnclass...big-bore-short/
Posted 20 January 2021 - 03:53 PM
Thanks Nick, hydro pipe comes up alongside the fuel pipe I think. Maybe the DSN would be OK. The 2 usual suspects, to thermostat cover or water pump I think would be problematic at the bulkhead end. Might have to fit the underneath ones if top ones won't go.
Posted 20 January 2021 - 04:45 PM
Pop up a picture so I can see.
Posted 20 January 2021 - 05:14 PM
Poor picture I know but you can see the layout. Unfortunately the shell is with the welding guru at the moment so can't take a better piccie.
Posted 20 January 2021 - 05:20 PM
It will be fine. The DSN bracket attaches to the two central and left ( looking from the front) studs/holes so will have plenty of clearance.
Posted 20 January 2021 - 05:24 PM
Thanks again.
Posted 20 January 2021 - 06:36 PM
There was 2 similar but slightly different Australian types used in Production that were fitted to all Mokes and Minis once they changed to the Rod Shift Gearbox.
I'll find some photos of both. One of these will fit for sure.
Posted 24 July 2022 - 09:28 AM
Just as a follow up on this subject. I contacted DSN and any other supplier that I could find and none offered a steady bar that would fit a hydro car on the LH side. DSN said that they hadn't considered hydro cars in their design. Moss said that they thought their water pump steady bar would likely fit but it doesn't without jamming up against the hydro union and forcing it out of position. I'm going to contact them to see if they could modify their bulkhead plate to overcome this problem.
Just like to thank Spider for his input on this and pictures of his own bulkhead plates he's made for Mokes for thermostat plate fixing.
Until I can drop an engine in for positioning I'm going to pause this problem.
Edited by whistler, 24 July 2022 - 11:36 AM.
Posted 24 July 2022 - 10:33 AM
The DSN on would still be a better option as it is mounted to the left of that pipe.
Posted 24 July 2022 - 11:05 AM
DSN say it wouldn't fit.
Posted 24 July 2022 - 11:31 AM
And I found DSN were not too sure about their steadies as well. Having fitted one I would say it would be a piece of piss to do. It uses three mounts to the center of the car and that hose would be fine as is.
the brake union is going through the outer of two clutch/brake holes in the cross member.
remains of an “ultimate” steady visible under the cables etc.
Posted 24 July 2022 - 11:40 AM
I'll have to study form when I drop the lump in. I've added another picture showing the fuel pipe alongside the hydro pipe.
Thanks for the photo of the DSN Nick.
Posted 24 July 2022 - 11:41 AM
Looking in DSN's catalogue it looks like it would - sits on the other side of the fuel line. Or you could fabricate a new plate for the one you have, doesn't look far off.
