Rear Quarter Opening Window Hinge
4 replies to this topic
#1 Chelsea_Pete
Chelsea_Pete
  • 66 posts
  • Local Club: London & Surrey MOC
Posted 21 January 2021 - 08:18 PM
Hi everyone,
My rear windows are the hinged opening type that have these catches: http://www.minispare...ic/CZH3536.aspx
Annoyingly the bottom hinge on each one has sheared off. They're riveted into the stainless frame. Does anyone know where I can find a replacement for the frame to save me getting whole new windows?
Looks like the part reference is CZH3537 but nowhere seems to sell it
Car is a C reg Mk 4
Cheers, Peter
#2 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 21 January 2021 - 10:39 PM
No longer available & haven't been for some time.
Only options are 2nd hand frame or fabricate new hinges (& even then you can't easily get the original style semi-hollow nickel plated brass rivets).
#3 blacktulip
blacktulip
  • 6,231 posts
Posted 21 January 2021 - 11:32 PM
Get some thin gauge stainless steel sheet and make some up. Then to fix them maybe try some jb weld or another strong adhesive. They won't move far once assembled again
#4 Chris1275gt
Chris1275gt
  • 1,029 posts
Posted 21 January 2021 - 11:53 PM
Hi everyone,
Car is a C reg Mk 4
Cheers, Peter
I've a couple of hinges you could have if you want them. I think theirs early and later ones the later ones being a little bit wider these are the early type. To fix them you need to drill the rivets out and drill the holes with a 4 mm drill and buy these from eBay item 223682198014. They are nickel plated and the heads are slightly larger but don't overhang the frame and look fine. Pm me. They are rust free and need a polish I'll dig them out tomorrow and take a picture if you want to see them.
Edited by Chris1275gt, 21 January 2021 - 11:56 PM.
#5 Chris1275gt
Chris1275gt
  • 1,029 posts
Posted 22 January 2021 - 12:45 PM
Off a 75 mini.
