Which Idler Needle Roller Bearing?
4 replies to this topic
#1 Coolingthunder
Coolingthunder
  • 76 posts
Posted 22 January 2021 - 03:56 PM
Hi folks,
Looking to replace the idler bearing on an A+ block, the current one is 35mmOD, 22.2mmID, a Torrington one. I want to replace because the needles have quite a bit of slack in them, you can move them back and forth quite easily, or is this normal? Current one is still the original one I think, marked Torrington.
I have read a lot of horror stories about these bearings going boom so want to know what I should replace them with.
Thanks!
#2 nicklouse
  • 18,998 posts
Posted 22 January 2021 - 04:40 PM
The block does not have an idler bearing.  The idler gear and bearings are housed in the gearbox and transfer case.
i presume you have an A+ engine and have a later rod type gearbox.
have a look on Guessworks web site as he sells the right ones.
#3 Spider
  • 15,684 posts
Posted 22 January 2021 - 05:31 PM
Be aware of some of these Bearings getting about out there, they are sub-standard. Do a search for Counterfeit Bearings.
Torrington were bought out by Timken, who then sold them to Koyo Bearings. These are all good quality and equal to OEM.
#4 Coolingthunder
Coolingthunder
  • 76 posts
Posted 25 January 2021 - 09:52 AM
Hi Moke, reading some of these threads is what actually made me make this post. I started getting the impression Koyo was no good anymore either, and ended up being more confused than I was at first (maybe I should stop going on googling sprees at 1am but that's something else)
I messaged John Guess, awaiting his reply. Finding halfway decent quality parts (especially critical ones like bearings) can be such a hassle sometimes.
#5 Spider
  • 15,684 posts
Posted 25 January 2021 - 10:39 AM
Koyo, NSK, FAG, NTN, INA, RHP are all good.
Koyo are effectively OEM on these cars.In the Gearbox and suspension, their's are about the only ones I fit now.
