Does Anyone Know Where This Bolt Goes ...?
Best Answer beardylondon , 24 January 2021 - 02:03 PM
Master cylinder, as per no.19
http://www.minispare...o.aspx?2~17~142 Go to the full post
9 replies to this topic
#1 Bobbins
Bobbins
  • 1,525 posts
Posted 24 January 2021 - 01:56 PM
I’m doing a full refresh on an 1986 998 A+ engine and this bolt has me stumped! I thought I’d labelled everything but then it was left over after cleaning parts through my ultrasonic bath at the time I had the carb stripped ... which is now back together! I’d kept assuming it was the clutch slave cylinder mounting bolt but that’s a fully threaded bolt that I’d labelled separately, plus the shoulder on this is too long to fit with the sleeve.
It’s 1/4” UNF x 2”, obviously very specific due to the substantial shoulder.
Can anyone take a guess?
Stu.
#2 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 24 January 2021 - 01:59 PM
Is it the bottom Rad bolt....
#3 beardylondon
beardylondon
  • 1,725 posts
Posted 24 January 2021 - 02:03 PM   Best Answer
Edited by beardylondon, 24 January 2021 - 02:04 PM.
#4 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 24 January 2021 - 02:12 PM
Oh mine are too old for that "part"... all pre 1981 here
#5 Bobbins
Bobbins
  • 1,525 posts
Posted 24 January 2021 - 02:13 PM
It’s about half the size of the bottom rad bolt!
I did wonder whether it was the mounting bolt for the brake valve but there seemed way too much clearance through the casting, the spec is correct though!
Brilliant :)
#6 richmondclassicsnorthwales
  • 942 posts
Posted 24 January 2021 - 02:48 PM
If it is 1 inch & 3/4 long then it is a BH604141, that,s the size I think, then if so,  look at
https://www.minispar...c/BH604141.aspx
#7 nicklouse
  • 18,998 posts
Posted 24 January 2021 - 03:01 PM
Brake limiter to front cross member bolt.
#8 Spider
  • 15,684 posts
Posted 24 January 2021 - 04:58 PM
I'm not so sure guys, it is a little odd as it has a long shank and a short threaded section. I could well be wrong, but to me it does look like a special for something specific.
#9 Revd
Revd
  • Just Joined
  • 81 posts
Posted 25 January 2021 - 07:41 AM
This,
#10 Rorf
Rorf
  • 866 posts
Posted 25 January 2021 - 12:56 PM
I would agree
