Reaming - Rear Radius Arms
Posted 24 January 2021 - 03:51 PM
H15 Expanding Adjustable Reamer 1.1/2" - 1.13/16" 38.10mm To 46.03mm
Thanks in advance
Posted 24 January 2021 - 03:56 PM
It's just 13/16" not 1 - 13/16"
it needs to be reamed concentrically to the bearing diameter, the original ones had a bush to go where the bearing fits and the reamer is a longer rod that is supported by the bush.
Edited by alex-95, 24 January 2021 - 03:58 PM.
Posted 24 January 2021 - 04:55 PM
As Alex said, needs to be 'guided' so it lines up with the Bearing. If you look about you might find a Reamer Pilot that's long enough.
Posted 24 January 2021 - 05:44 PM
Ac
Edited by ACDodd, 24 January 2021 - 05:46 PM.
Posted 24 January 2021 - 06:02 PM
Posted 24 January 2021 - 06:03 PM
Just about to make up a few of these sets,
Ac
They look pretty neat. What would this cost?
Posted 24 January 2021 - 06:14 PM
it features hardened steel arbour, changeable cutters when it eventually wears out, a brass bush to align the tool with the other end of the radius arm, and a drill mounted bore polisher to take care of oversized shafts that are sometimes found in the aftermarket rebuild kits, or to apply a clearance if you like to run a bit of extra grease clearance.
£195 plus shipping.
Ac
Posted 24 January 2021 - 06:46 PM
Ac
That's a nice bit of kit, very nice !!
Posted 24 January 2021 - 07:45 PM
Sure is, I guess depends what it cost to get replacement arms or your own reconned, must admit I have never replaced rear arms / bearings / bushes other than the ones I bent...if "new" and greased properly and regularly they pretty much dont wear out I believe
Posted 24 January 2021 - 09:38 PM
Ac
Posted 24 January 2021 - 09:45 PM
Yes I agree with you AC.
Posted 24 January 2021 - 09:47 PM
Posted 24 January 2021 - 10:28 PM
Just about to do this job myself and was thinking I'd give it a try to see how well it works
Posted 25 January 2021 - 07:00 AM
Thanks for the quick responses. Back to trying to find the correct size reamer. Would you suggest a tapered reamer or not?
Hand Reamers are Tapered, Machine Reamers are Parallel.
The Taper on the Hand Reamers is only on the first 1/3 of it's length, then they are parallel.
Posted 25 January 2021 - 01:29 PM
Got mine here.
Can't remember if it was that exact one, I rang 'em & told 'em how long it needed to be. You'd either have a bush made up for the bearing end (like AC's), or figure out a way to extend the nose - maybe by making it screw on to the turned down end of an old pin.
Sure there's an old topic somewhere.
