Good evening everyone.
I currently have the oil sender on the engine not connected to anything. I need to run a new wire from the sender to the dash to make an oil pressure warning light. Would the below setup work correctly when attached to a switch live?
Thanks in advance, yours Babs
adjustable-low-oil-pressure-switch-35psi-set-from-merlin-motorsport.jpg 25.66K
0 downloads
Installing Oil Pressure Warning Light
babsbrown
, Jan 24 2021 04:31 PM
5 replies to this topic
Posted 24 January 2021 - 04:31 PM
Posted 24 January 2021 - 04:56 PM
Yes but I'd add a suitable fuse. Why not use the existing light in the dash?
Posted 24 January 2021 - 06:51 PM
Thanks, I would but I converted to an older centre binacle dash over 10 years ago, and i fear that by taking it all apart again, I'm going to cause my self so many head aches! As I can't remember which wires were what haha
Posted 24 January 2021 - 06:54 PM
Would it be worth running a guage instead?
Posted 24 January 2021 - 07:09 PM
Run both
Posted 24 January 2021 - 09:50 PM
Run bothWould it be worth running a guage instead?
I agree and have the light on a 20psi switch.
An old stock car racing trick is to wire the light so it is out when the engine is at pressure, then lights at the set pressure.
