Pot Joint Refitting
9 replies to this topic
#1 sam138
sam138
  • 524 posts
Posted 26 January 2021 - 07:25 AM
Could anyone suggest how I get the below point joint into the gearbox, I’ve put the engine in and managed to get passenger side fitted but the other one is lined up but just won’t slide in ?
Attached File  CECB4D19-7340-4C54-9E56-2AF886BB7652.jpeg   62.83K   2 downloads
#2 weef
weef
  • 558 posts
Posted 26 January 2021 - 09:02 AM
Usually the pot joints are fitted before you fit the engine, it is easier.
The joint has a snap ring that needs to be shock compressed. If the ring integrity is good and the joint is lined up as you say a sharp knock with a mallet will seat it.  It may be best to work from under the wing using something like a piece of wood dowling as an extension.
#3 whistler
whistler
  • 1,898 posts
Posted 26 January 2021 - 09:34 AM
Be aware that if the joint is forced towards the diff it is possible that the C ring can be distorted and will jam the whole assembly. I usually use a piece of 4x2 timber vertically down from the engine top and use it to lever the joint in rather than tapping with a universal spanner.
#4 Spider
  • 15,865 posts
Posted 26 January 2021 - 06:43 PM
It'll be the C Clip as the other guys have suggested. The C Clip may have been replaced at some earlier point and in doing so, expanded too much an end can come out of the groove and the Joint goes on. As Whistler says, forcing it when they get to this point will only result in it Jamming.
Remove the Joint and check the C Clip. If you can push one side in to the groove with your finger and the other side comes clear of the Splines, then it's been over-expanded. You maybe able to remove it, bend it back in tight, at this point, I bend the ends in a wee bit tighter than the rest of the clip so that they don't pick up on the Joint when removing it down the track. When refitting it, only open it just enough to slip over the splines and no more.
It's actually a lucky find. If it fell in to the slot in such a position that the Joint could be refitted, when removing the next time it would become quite an ordeal.
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 26 January 2021 - 07:13 PM
As said the c clip can cause problems. Is it a new pot joint or has it been fitted previously? The new pot joints are usually oversize, I found this out when I was fitting mine and couldn't get it in >_<
#6 sam138
sam138
  • 524 posts
Posted 26 January 2021 - 10:20 PM
Thanks for the replies, these are the original pot joints not new ones. Will try and pop the joint out and have a look at the C clip.
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 26 January 2021 - 11:00 PM
Put some thick, sticky grease on the C clip so it does not droop down and try to align it to be concentric with the splines. Try again the installation.
#8 Chris1275gt
Chris1275gt
  • 1,052 posts
Posted 27 January 2021 - 10:05 AM
I always align it with the split at the bottom with the shaft at a slight angle upwards to just get the top in then jiggle up and down while gently pushing and it usually pops in 9/10 times though putting the grease in as above is a good idea.
#9 sam138
sam138
  • 524 posts
Posted 31 January 2021 - 09:14 AM
Thanks for the replies, what’s the best way to get the pot joint back out again ? I’ve tried wiggling by hand but won’t come off splines. Do I need to disconnect the top ball joint to lean the hub back ?
#10 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 31 January 2021 - 01:27 PM
If you have some play left in the driveshaft you can gently knock it with a hammer and a bit of wood and it should come back off.
If you have zero play split the top ball joint and it should give you some extra space.
They can be a pain.
