Question On Lower Steady Rod Fam2758
5 replies to this topic
#1 hungdynasty
hungdynasty
  • 179 posts
Posted 27 January 2021 - 03:53 PM
Sorry if it sounds stupid to you, should this bar be installed with a certain side toward the front, or it really doesn't matter?
#2 nicklouse
  • 19,064 posts
Posted 27 January 2021 - 03:59 PM
Does not matter.
#3 whistler
whistler
  • 1,898 posts
Posted 27 January 2021 - 04:19 PM
If this is a new steady bar fit just make sure that the bolts or studs which attach the mount plate to the gearbox are the correct length otherwise you could end up stripping the threads on the gearbox/case.
#4 nicklouse
  • 19,064 posts
Posted 27 January 2021 - 08:13 PM
MIniSpares do longer studs. And note it does little to stop rocking but helps keep the engine in place.
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 28 January 2021 - 10:09 PM
I've changed all mine for these ajustable I use 4 in all
#6 hungdynasty
hungdynasty
  • 179 posts
Posted 29 January 2021 - 06:02 PM
Replaced, look at the broken one, awful welding.
