Impact Wrench
20 replies to this topic
#1 E1LDR
E1LDR
  • 48 posts
Posted 31 January 2021 - 04:49 PM
Searched the forum and have seen mixed reviews, would this be adequate for jobs on the mini. Reason for wanting to purchase is I need to get the front hub nut off. Unable to release with breaker bar as the rear end of the car is on axle stands.
https://www.halfords...ah-826047.html?
#2 Tones61
Tones61
  • 433 posts
Posted 31 January 2021 - 04:57 PM
Milwaukee 1/2 drive gun, (the fuel range),
Anything else is 2nd rate,inc likes of snap on,
Using them at work
#3 PoolGuy
PoolGuy
  • 854 posts
Posted 31 January 2021 - 04:58 PM
I’ve got that same impact driver, it hasn’t failed to undo anything that I’ve asked of it. Ryobi tools have really improved over the last five years or so. If you’re not a tool brand snob, go for it.
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 31 January 2021 - 05:27 PM
Brushless Milwaukee gets the best ratings at the minute.
#5 nicklouse
  • 18,658 posts
Posted 31 January 2021 - 05:33 PM
Make tool to hold the hub. And just use a breaker bar.  Impact tool or not you will still need to hold the rotating parts.
#6 Maccmike8
Maccmike8
  • 1,101 posts
Posted 31 January 2021 - 05:34 PM
Or get someone to step on the brake pedal.
#7 nicklouse
  • 18,658 posts
Posted 31 January 2021 - 05:40 PM
Often not not enough force There.
#8 Tornado99
Tornado99
  • 750 posts
Posted 31 January 2021 - 05:54 PM
Ha ha! I bought my first impact gun specifically to do that hub nut as well!
Seeing that nearly 200 ft-lbs is needed there, I went with a gun rated for at least that amount. Looking at the rechargeables price tags really put me off, esp when seeing the top ones didn't include a power pack, toss in another $100 for pack and base charger.
Ultimately went with a hard wired "BFG" on clearance for $80. Almost went with a good used one on local buy and sell site but the new one was such a good price.
Took that nut off in a second.
#9 Maccmike8
Maccmike8
  • 1,101 posts
Posted 31 January 2021 - 05:56 PM
Its worked for me both times.
Edited by Maccmike8, 31 January 2021 - 05:57 PM.
#10 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 31 January 2021 - 07:15 PM
Depending on your circumstances, room for storage, usage etc, the advent of the battery powered tools makes compressors and air tools second hand very cheap... obviosuly not as portable as battery tools, but once you have a compressor you will wonder how you ever managed without one...even for silly things like blowing dust off filters, or drying a joint to check for any new weepage..
#11 Tornado99
Tornado99
  • 750 posts
I managed to put a length of 2x4 lumber between the hub studs and braced to the cement floor to hub the hub from spinning, using another bit of wood to hold force on the brake pedal, braced against the frame cross member.
#12 E1LDR
E1LDR
  • 48 posts
Posted 31 January 2021 - 07:33 PM
Thanks for all the comments. I’m not a tool snob by any means, as long as it does the job with no effort then that’s Okay for me.
#13 Spider
  • 15,045 posts
Posted 31 January 2021 - 07:58 PM
I've gotta say, I'm not a fan of any Impact Gun, nothing against any brand etc, I just don't like the way they work.
Yes, I do have 3 though ! But can't recall the last time I used any of them.
In your predicament here, I'd suggest grabing a short length of 2-1/2" Angle Iron (1/4" thk), drilling 2 x 10 mm holes in it for 2 adjacent studs to go through and bolt up the hub to it with a couple of wheel nuts. You could use this on car, but I use mine 99% of the time, on the bench.
#14 Icey
Icey
  • 1,552 posts
Posted 31 January 2021 - 10:09 PM
I have the same one, great for everything I've needed it for on both Minis and MINIs.
Edited by Icey, 31 January 2021 - 10:09 PM.
#15 Maccmike8
Maccmike8
  • 1,101 posts
Posted 01 February 2021 - 09:28 AM
I have Ryobi products and kind of made my bed with them with the amount of batteries I now have.
My drill recently packed up and wanted to go Milwakee but couldnt justify starting ahgain with batteries etc.
So my advice, is buy Milwakee to start with.
PS my Ryobi impact gun probably wouldnt undo the hub nuts fyi.
