Start with fresh fuel and go drive the car and get some heat into it.
Engine Won't Run Properly After A Month Sitting
#16
Posted 06 February 2021 - 07:58 PM
#17
Posted 07 February 2021 - 02:08 PM
Had this issue before, try fresh fuel before you do anything.
#18
Posted 11 February 2021 - 06:14 PM
It's still running rough but it's a big improvement and I think that's probably because there's still some stale fuel in there. I'll get another can of fuel tomorrow and try and mix it in with my dipper and we'll see how well it goes.
#19
Posted 11 February 2021 - 06:36 PM
#20
Posted 11 February 2021 - 06:51 PM
#21
Posted 11 February 2021 - 09:47 PM
Dont do what my mate did and use any safely contained 99 octane in a 2 stroke mower... It blew its guts out 😳😒
Edited by cal844, 11 February 2021 - 09:48 PM.
#22
Posted 19 February 2021 - 03:57 PM
Quick update on this. You know how it's never the coil? It was the coil.
After a week of topping up with 99 octane fuel the car was still not running properly. It would take 30-45 seconds of cranking to start then it still need a massively rich mixture and full choke to run.
When I sat down and looked at everything that had been changed or checked I realised the only thing left was the coil. So I chucked on a new one and she started within seconds. Looking at similar posts on here where there was a coil issue most seemed to recommended converting to a non-ballast coil so I did that at the same time.
I'll need to go back through and set the mixture properly and recheck the timing but it's looking much better now.
I've got one last question, the spark plugs are really sooty now, presumably from the rich mixture, can I clean them or should I chuck them? I know they're cheap as chips but they're only a few weeks old so if I can clean them up then I'd like too
#23
Posted 19 February 2021 - 04:49 PM
#24
Posted 21 February 2021 - 10:35 PM
