2 Pin Flasher Relay
4 replies to this topic
#1 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 07 February 2021 - 02:13 PM
Hi all,
I'm in the midst of sorting my 1980 Mini Van wiring out currently and have removed and relocated a fair few relays and wires. I've got to the 2 metal w pin relays that side on the N/S bulkhead that i THINK are for the hazards. I'm going to be moving them to behind the dash binacle and was wondering if there is a modern day equivilant? As the ones i have are severely corroded.
Edited by Steve220, 07 February 2021 - 02:14 PM.
#2 KTS
KTS
  • 2,462 posts
Posted 07 February 2021 - 02:33 PM
2 pole flasher and hazard relays are still available
https://www.autospar...r-units?cat=222
the modern equivalent would be an electronic type which (will require an earth connection being added if replacing a 2 pole unit).
#3 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 07 February 2021 - 02:38 PM
Cheers chap. I may just have to bite the bullet and get exact replacements in your link. Was hoping for a plastic housing one.
#4 Ethel
  • 26,082 posts
Posted 07 February 2021 - 04:15 PM
You can get electronic 2 pin flashers, but I don't see the advantage. The steam powered ones have built in fault finding  :D
#5 Spider
  • 15,146 posts
Posted 07 February 2021 - 07:27 PM
The Electronic versions are silent in operation, so you need to keep a check on the dashboard tell tales.
Also, these days, many are only rated for LED Lamps, though conventional bulb types are still available, just check what you're buying.
