Bonnet Strap
Posted 09 February 2021 - 10:38 PM
Any help would be much appreciated
Thank you
Posted 09 February 2021 - 11:21 PM
Is there any other way of fitting them without drilling holes in the bonnet! I was thinking velcro or something? I just want it for looks.
Thank you
You could use 3M high strength adhesive tape. That will hold up very well on exterior surface and it will be possible to remove it in future without damaging paint. Using a hot air gun (even hair dyer) will help soften the tape enough to work it loose. Also tricks like running dental floss under the item to "saw" through the tape will help, then just use some adhesive cleaner to remove remnants ("Goof Off" or WD-40 work pretty well without paint damage.
Posted 10 February 2021 - 10:06 AM
