New Quarter Window Seal Leaking
14 replies to this topic
#1 rae07
rae07
  • 48 posts
Posted 10 February 2021 - 12:44 AM
So I have replaced my quarter window seal for my hinged window. But now my windows don't sit square. The leading/front edge is flushed with the body but the rear edge is not flushed. Sticks out about 1-2cm.
Anyone experienced this before and any luck in resolving it?
#2 colinf1
colinf1
  • 1,031 posts
Posted 10 February 2021 - 09:53 AM
Have you used the correct seal and not one for the fixed windows?
#3 rae07
rae07
  • 48 posts
Posted 10 February 2021 - 10:05 AM
Affirmative. I've attached the pics for reference.
#4 colinf1
colinf1
  • 1,031 posts
Posted 10 February 2021 - 12:31 PM
Can you show a picture of the seal?
#5 rae07
rae07
  • 48 posts
Posted 10 February 2021 - 04:39 PM
I've got no chance to take a clear pic due to lighting.have attached a similar seal type instead.
Edited by rae07, 10 February 2021 - 04:40 PM.
#6 Ethel
  • 26,104 posts
Posted 10 February 2021 - 07:33 PM
That's the correct type of seal. How does it compare to the old one for size? It's a generic sort of moulding, so you could have got something similar, but not specific.
#7 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 10 February 2021 - 07:41 PM
New rubber tends to be harder so it may take time to "squish" ..
#8 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 10 February 2021 - 09:42 PM
Are your opening hinges solid or loose at the mounting screws?
Edited by Spherix, 10 February 2021 - 09:42 PM.
#9 rae07
rae07
  • 48 posts
Posted 11 February 2021 - 03:38 AM
the hinge and mounting are tight. old ones are definitely flatter. but i don't think it would have resulted in such difference. One of the possibility is that it is pinching too much on the leading edge causing the trailing edge to be alleviated. But the front is flushed and it does not look like it is overtightened.
#10 Ethel
  • 26,104 posts
Posted 11 February 2021 - 12:37 PM
Think you're on the money there. The hinges make quite an indentation in even the rubbers they left the factory with.
Push on the glass carefully. If you can close the gap without too much effort, some packing under the catch may pull it in. Suppose you could even  rig up a ratchet strap & some lengths of timber as a tribute to orthodontists.  :P
#11 sonscar
sonscar
  • 3,062 posts
Posted 11 February 2021 - 01:24 PM
Looks like a generic type seal.Close the window without it in,measure the gap,then search for a seal of this size.Not original perhaps but would be my choice.Steve..
#12 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 11 February 2021 - 02:18 PM
My opening quarter light seals were like this when first fitted. The rubber will soften slightly and the windows will eventually sit a bit more flush with the body aperture.
As suggested, gently pushing on the window from the outside will help squash the rubbers in a little.
Cheers, Steve.
#13 rae07
rae07
  • 48 posts
Posted 16 February 2021 - 01:23 PM
Thanks for the great help. Gonna put some rubber grease ard the seams and see if helps. On the seal, are there difference sizes?
#14 Ethel
  • 26,104 posts
Posted 16 February 2021 - 06:09 PM
Shouldn't be, but there are plenty of similar generic mouldings that could be sold for the job. Did you buy it from a Mini specialist?
https://www.minispar...|Back to search
#15 MikeRotherham
MikeRotherham
  • 990 posts
Posted 16 February 2021 - 10:02 PM
The last time I replaced mine, a few years ago, the bit that fits on the metal flange had a ridged appearance like the originals. The seal had a square more compact appearance as opposed to the round one in your image. It's quite a small space that the seal and window have to fit inside.
A couple of examples
https://www.ebay.co....BIaAgHZEALw_wcB
Edited by MikeRotherham, 17 February 2021 - 08:23 AM.
