Limited Sunroof Choice
5 replies to this topic
#1 Metrodave2020
Metrodave2020
  • 25 posts
Posted 14 February 2021 - 12:54 PM
I have always wanted a folding sunroof, partly because I love driving with the open sky above but also they remind me so much of Minis I liked when a lad in the 60’s early 70’s – particularly the shorter ones.  Just in case anyone else is thinking of going down that route, the after-market Hollandia 400 electric roll-back roof is no longer made.  They will continue to supply to manufacturers but the equivalent of the full length roof that was fitted to the British Open is no longer manufactured; I am lead to believe parts are not readily available either, in case you are looking at used.
I have considered the Britax Weathershield / Webasto roof (they are pretty much the same thing) which come up on eBay quite often, rather surprisingly.  There is a potential catch with these insofar as whilst often described as being ‘complete’ they don’t ever seem to come with the bracing strip which was screwed or rivetted into the roof and sit in the inner roof’s perimeter channel.  These support the leading and rear edges of the opening and are necessary to support the roof and prevent the corners of the aperture cracking.  As roof profiles vary between vehicles these braces were individually prepared to match the car by hand-forming over an anvil.   Therefore, even if you find a used Britax Weathershield / Webasto roof with the bracing bars, unless it came off another Mini they will not fit unless altered to the correct length and shape.  A roof from an MGB GT or anything else will probably not fit, although no doubt those with necessary skills might be able to make it work.
I hope that helps anyone thinking of doing this.  My recent conversation with a sunroof installer with several decades experience including the Webasto type very strongly recommended not buying a used roof.  He was not even prepared to fit a used one as he no longer has the ‘bridge’ which I understand would have been used as a former to create the bracing bars. Also, spare parts are impossibly difficult to find.
Cutting a hole in a solid roof was never going to be straightforward but I’m now completely put off.  A genuine Tudor Webasto roof (which has wooden supports) is available from https://www.thetrimmingcentre.co.uk/ and will cost around £2.2k plus VAT.   Actually, this seems relatively good vale for a properly installed roof.
Cheers, David
#2 sonscar
sonscar
  • 3,039 posts
Posted 14 February 2021 - 01:38 PM
Do not over think this,I fitted a used roof in my MGB no anvil required bent the 6?mm bar over my knee to the needed curve.Took some brave pills and cut a hole in the roof.It was not rocket science and could be done by anyone who has a grasp of bodywork.Just my nonprofessional view,yours may vary,Steve..
#3 Chris1275gt
Chris1275gt
  • 965 posts
Posted 14 February 2021 - 02:47 PM
If you do buy a used one it would have to be out of a mini and be aware the trimming centre will not sell you any part at all no matter how small, believe me I've tried they will sell you the entire fixing kit though.
#4 Metrodave2020
Metrodave2020
  • 25 posts
Posted 14 February 2021 - 08:43 PM
Thanks for the feedback, both of you...regarding Sonscar's DIY installation, yes I agree that someone with necessary skills would be able to make it work.  But it's one of those tasks where there is no easy route back if it goes wrong!  I just wanted to make others aware that it isn't completely straightforward. A Webasto roof apparently still in its original box has just gone for over £1100 on eBay but the photos don't appear to show it includes the essential bracing bars.  That might work out an expensive purchase if you can't find anyone to fix it, if you can't do it properly yourself.
David
#5 Chris1275gt
Chris1275gt
  • 965 posts
Posted 14 February 2021 - 09:12 PM
David
If you go to this old web page you can download the fitting instructions for the old style sunroof the corner braces are pictured and they could be very easily fabricated.
http://www.tudorwebastosunroofs.com/
#6 Metrodave2020
Metrodave2020
  • 25 posts
Posted 14 February 2021 - 09:27 PM
Thanks Chris1275GT - that's a great resource!
If anyone else is interested, the instructions are here http://www.tudorweba...anual_part2.pdf
and
http://www.tudorweba...anual_part1.pdf
