Clubman Bonnet Fit - Inner Wing Width
5 replies to this topic
#1 Verderad
Verderad
  • 413 posts
Posted 16 February 2021 - 09:38 PM
The bonnet gap on my clubman is terrible on one side.
I have replaced the whole front end, inner wings, scuttle, Hinge post.  the lot.
I currently have it all screwed together.
I bought a 2nd hand bonnet, it was split in the centre and has some rust, Ive stripped the bonnet into pieces, treated, painted and put back together.
Trial fit bonnet , 5mm bonnet to wing on offside front and back.
Near side 5mm at front and 8 > 9mm at  rear.
Purchase new bonnet - Fit is worse that the other bonner I have.
Makes me question if I have the from on correctly?
The inner wing is tight up against the bulkhead
The scuttle looks like is in the right place.
The wing to scuttle is good
bT8iu2l.jpg?1
I cant see how I can get the inner wing over further
If I could I don't see that the wing to scuttle will allow for any more movement
Any suggestions?
Can someone measure inner wing to inner wing at front and just in front of Scuttle please
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 16 February 2021 - 10:05 PM
Is the bonnet a pattern one or Heritage??
Is the scuttle fitted or clamped in place.
Have you dressed the return under the wing back as you may get a bit more movement there plus you could sharpen the fold on the wing where it wraps against the scuttle.
I replaced my clubby bonnet with a Heritage item and still had a small runout but this was solved with some cutting and adding in metal. Not a big gap like yours.
#3 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 16 February 2021 - 10:10 PM
This was how tight i got my gap on the r/h side
a9d07358d47d10d93ac02ae10a6136f1687c22d9
And some measurements that might help you.
b3c597ccf4cfd71e5759acef7e7e7faa42b14f75
And this was the run out you can see at the back of the bonnet. This was the original bonnet as well. The previous wing gap was bad but no pictures of them.
e769f8e51ca3e5341508aafdeb2a6667a60837e1
#4 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 16 February 2021 - 10:28 PM
This was a replacement bonnet i had and the gaps were much the same including the runout.
335dba8c13d0fd4e9b52a037c454308d2b60c2cf
8d5f52f2695d95dcdfe78aebce8e5d4de601617f
#5 CK's mini
CK's mini
  • Just Joined
  • 113 posts
Posted 17 February 2021 - 07:33 AM
I had this problem, I set up the frontend using the original rusty bonnet, gaps were great  :D
I then purchased a heritage bonnet and the Gaps were massive  O_O
I did find the the new bonnet was curved so the center was higher than the scuttle panel. A bit of questionable pressure in the correct locations has improved it. I have also seen people cut down the edge and pull it over to improve the gap then make good but I was too scared to do that to a brand new bonnet.
Good luck with it  ;D
#6 Verderad
Verderad
  • 413 posts
Posted 17 February 2021 - 04:45 PM
Heritage new purchase from Bul Motif
It’s screwed in 5 points, I have a slight gap in couple of places, will add a few more screws.
Not sure what you mean by return. Your wing appears to touch the drip gutter on the scuttle. Mine had a fairly big gap both sides (will get a picture) I will try to sharped the wing at scuttle joint. The gap at the top is good but might squeeze a mm out.
Yes making up 4mm is going to need more than a slit and weld. Adding material is going more welding, heat and ripples
Thanks fior the help and pictures
