Why Do They Not Supply A Replacement Clutch M/c Push Rod?
10 replies to this topic
#1 floormanager
floormanager
  • 705 posts
  • Local Club: Mini Club Sussex
Posted 17 February 2021 - 07:25 PM
Like they do for MGBs?
https://www.moss-eur...er-17h7985.html
Mine is worn and I want to replace it but I have to buy the entire master cylinder. Why can't the mini parts suppliers sell them?  They must be made as they are supplied with new master cylinders.
#2 GraemeC
GraemeC
  • 7,439 posts
Posted 17 February 2021 - 08:23 PM
Supply and demand? For most people, if the push road is that bad the master cylinder is probably due replacement too.
You used to be able to buy them - 17H7557
#3 floormanager
floormanager
  • 705 posts
Posted 17 February 2021 - 09:33 PM
can't anymore.  Only for MGs.  Not sure what the difference is between the 17H7557 and 17H7985.  Might get one and see.  I want to keep the M/C if possible but want to replace the push rod.  Might have to buy a new M/C and remove the push rod.  Just seems unfair that MGBs can have that option.
#4 GraemeC
GraemeC
  • 7,439 posts
Posted 17 February 2021 - 09:54 PM
Probably a different length.
I may have a used one spare if that any use?
#5 richmondclassicsnorthwales
  • 942 posts
Posted 18 February 2021 - 08:02 AM
Same can be said for Spitfire Master Cylinders, some manufacturers do not supply the pushrods.
Pushrods can be different sizes, you would think it would make sense to make a standard pushrod of equal length to be used on different cars -especially given that a lot come from BLMC playground
Cost cutting I think you will find is the word.
#6 Ethel
  • 26,016 posts
Posted 18 February 2021 - 10:43 AM
It appears both are 3/4" inch bore. Could be interesting what any length difference makes to the height offset with the brake pedal.
https://www.merlinmo...-clevis-gmc-clv ?
https://www.mgexp.co...length.2927795/
Not sure that doesn't just add to the confusion, but something sounds about 3/8" longer as a very rough estimate
#7 floormanager
floormanager
  • 705 posts
Posted 18 February 2021 - 07:23 PM
They say a fool and their money soon parts.  Well, to abide by the rule, I ordered one from Moss to see what the difference is.  And, drum roll please, to the naked eye, the only difference I can see, is the dust cover collar on the shaft!
Attached File  pushrod2.JPG   55.19K   0 downloads
#8 floormanager
floormanager
  • 705 posts
Posted 18 February 2021 - 07:24 PM
And they wondered why they never made any money!
#9 floormanager
floormanager
  • 705 posts
Posted 18 February 2021 - 07:43 PM
Now this has got me thinking...
#10 Ethel
  • 26,016 posts
Posted 18 February 2021 - 11:32 PM
Don't know why I didn't spot https://www.merlinmo...nders-obpcb005s
Even better, but a little bit dubious if there'd be room for either - how much of the lotal length needs to be able to go through the retainer washer in to the cylinder  :unsure:
#11 nicklouse
  • 18,656 posts
Posted 19 February 2021 - 12:02 AM
There are issues with length here. See my fitting of the KAD clutch kit
https://www.theminif...date-it/page-50
