Speedo Operating Intermittently
Posted 20 February 2021 - 04:35 PM
Posted 20 February 2021 - 04:50 PM
It does sound like the cable has failed or come disconnected.
changing it is not that hard.
Posted 20 February 2021 - 07:03 PM
Posted 20 February 2021 - 07:17 PM
I'd be sure it's the Speedo Drive Pinion in the Gearbox slipping, somewhat common issue.
You can change it with the engine in situ. Either remove the Radiator and come in from the top, or I tend to come in from under. Jack the car up high n the LH side, then you can remove the Pot Joint without draining the oil. After that, access is good.
To check if it's the Cable or the Pinion, undo the cable off the back of the Speedo and then try and twist the inner core. If it feels rough or indeed spins, then it's likely the cable. If it feels firm, then it's likely the Pinion.
Posted 21 February 2021 - 03:16 PM
Posted 22 February 2021 - 06:26 PM
Can be a bit awkward but is easily replaced👍
