Battery Cable
7 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 21 February 2021 - 05:41 PM
Just about to put the battery cable  back on the car, horrible job,.................... at the battery end I have seen on this forum pictures that show the route at the rear end ( BOOT)  ...comes out the channel under the car, and then goes up between the back of the floor and rear subframe then neatly into the boot floor, have also seen and if I recall, mine was the same, that the cable comes out the channel, then just loops over the rear subframe into the boot floor?..... to me the first method seems neater, BUT is it do-able in situ? or was it done when the rear subframe was out?  Must learn how to post photos :(
Secondly, where the cable comes out of the front, what's the best route from then on ?    just don't like the idea of cable tying it to the front subframe as they are unsightly ghastly things......ties I mean not subframes....
Cheers.
#2 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 21 February 2021 - 05:48 PM
Out of the factory the Cable went over the subframe into the boot floor then the connector was fitted to the cabe (I think) once inside the boot.. The cable I believe is pokable through above the subrame with it in situ, but I am sure it wont with the battery terminal connected..
#3 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 21 February 2021 - 06:08 PM
for me the battery cable was always under the subframe and tied in the corner with two P-clips and then goes in the boot. I changed one not long ago ;)
#4 imack
imack
  • 2,372 posts
Posted 21 February 2021 - 06:21 PM
As Gilles1000 says, cable did not go between subframe and body, it runs beneath the subframe and is secured to the subframe with P clips.
#5 Spider
  • 15,684 posts
Posted 21 February 2021 - 06:29 PM
It might have been Australian Production ? however, in the Rear, the Cable went between the body and the subframe, along with the Brake Line and on the other side, the Fuel Line and in the later cars, the Vapor Return Line.
Have a look here
https://www.theminif...onto-tmf/page-5
#6 humph
humph
    How bad can it Be?
  • 1,124 posts
Posted 21 February 2021 - 07:18 PM
I’ve just fitted mine between the body and subframe whilst the subframe was insitu. Was expecting a battle but all went in quite easily. I fed the front end of the cable out of the boot and between the body and subframe before running it to the front and putting it in the channel. Mine was a brand new cable as part of a full rebuild though.
#7 splintercat
splintercat
  • 616 posts
Posted 21 February 2021 - 07:47 PM
Thanks for all the replies, would love it to go between the sub and body, I will have a go but if it fails, over it goes......
#8 humph
humph
    How bad can it Be?
  • 1,124 posts
Posted 22 February 2021 - 09:11 AM
Worth noting, as it may have made the job easier, the new cable I used has a 90 degree bend in the engine end terminal.
