My ‘65 Elf had been fitted with a 1275 A+ engine before I bought the car. I’m a bit concerned about the dipstick and it’s fitting. It is very loose in the hole in the cylinder block, the stick has a bit of a plastic seal around it but as I say it is a very loose fit.
is there supposed to be some form of tube, nipple or fitting missing from the block? If there is something missing the dipstick will be giving the wrong reading for the oil level.
The engine is, I believe a 1989 as fitted to a Metro and is a 12H DO9 111###
B03EA38D-EF9B-4301-89A1-B6B5AB98E4DD.jpeg 42K
1 downloads
915991E5-72F4-46CE-9D99-DAF1BF7AE64C.jpeg 41.79K
1 downloads
