As title says, I have a 1340cc Weber DCOE 45 with fast road cam and 1.5 lifters, when the engine is cold it'll idle at around 800 roughly, then after 5 or so minutes after warming up it'll rise to around 1200-1300, then i have to get out the car and lower it back down to 7-800, but then if i shut the car off and let it cool down it will idle so low and stall so i have to pulse the throttle or just get out and raise the idle again, also adjusting the choke helps very slightly, but then of course after warming up it'll go back up to 1300 or so, so i have to lower it back down
Hope i have explained this right, the engine runs fantastically otherwise, im sure the idle circuit is just set up wrong, any advice would be lovely
