Carb Hitting Bulkhead
Best Answer Vanman20 , 26 February 2021 - 03:52 PM
Fixed it by lengthening the stabiliser bar
Go to the full post
Posted 26 February 2021 - 11:52 AM
What's the common fix ? A big hammer on the bulkhead ? :)
Posted 26 February 2021 - 12:03 PM
a longer/adjustable engine steady bar can be used to tilt the motor forward to give clearance
..out of curiosity; what inlet manifold are you using ?
Edited by KTS, 26 February 2021 - 12:04 PM.
An adjustable top steady which you can unwind to canter the engine forward will solve the problem.
Later 1275 minis had the lower engine mounts moved forward in the subframe so this wasnt an issue but older subframes can make do with the above.
Posted 26 February 2021 - 12:04 PM
If you don't already have it a longer upper steady and a thinner carb spacer if you have the 1/2 thick type.
https://www.minispar...|Back to search
Posted 26 February 2021 - 12:52 PM
20210214_181204.jpg 42.68K 0 downloads
If you have clearance on the carb cable quadrant you can gain 1/8"-1/4" by thinning the spacer, I took .150"/4mm off. You can also shorten the studs so it's easier to remove the carb.
This is the clearance on the quadrant I have, I plan to take more off the spacer to make removing the filter easier.
Edited by bikewiz, 26 February 2021 - 12:57 PM.
Posted 26 February 2021 - 01:30 PM
