Wiper Parking Issue Calling Electrical Guru's
Posted 03 March 2021 - 08:46 PM
Wiper issues and questions. my wipers don't park but they do if I have the lights on. thats odd because there doesn't appear to be a link apart from earth points between the two? If you test the green/orange wire at the wipers it should be 12v with ignition on. It isn't it shows an odd reading of about 0.3v. however if you switch the lights on you get 12.4v???? Any thoughts as to where in the loom I would have to go back to. Would it just be easier to run a new switched live wire to the terminal on the wipers.
Second question is it possible to get rid of the wiper arm on the steering column and replace it with switches in the dash. Has anyone used an intermittent system along with the two speed motor. Any ideas on how to wire. I spoke to David at Wired by Wilson who's good at this stuff and he said its difficult to do as you need an on off on on switch. I'd be happy to go with two switches on for speed and one for intemittent and a third momentary switch for the jets.
Posted 03 March 2021 - 09:18 PM
Replacement park switches are low cost, easy to fit. I'd start there. I've seen most terminals and connectors under bonnet looking greenish and cruddy. Use a cleaning vinegar to remove such corrosion, get a little container to dip things in for a good half hour then rinse with baking soda solution to neutralize.
As for intermittant wipers, there as bit of kit available specifically for mini wiring connector. It is basically a relay with a built in capacitor. You use existing switch to turn on wiper, turn off immediately and wait until you need a second wipe, switch back on and leave it on. The relay repeats that same time interval to wipe again. This is the very same setup VW Passat's used to have back in the early '90's. When I found out the relay was a standard form factor as simple wiper relays, I fit one on my '84 VW Golf and it worked a treat. Might be possible to fit to a Mini without needing connectors etc.
Edited by Tornado99, 03 March 2021 - 09:19 PM.
Posted 03 March 2021 - 09:52 PM
i've seen a few intermittent systems available but wondered if someone has actually installed one. barring that I'd just like to get the park to work.
Switching to toggle switches rather than the column stalk would match the rest of my rally inspried dash. Its fairly straight forward with just the wipers i think. it would need a relay according to mr Wilson. The intermittent adds an additional complexity.
Posted 03 March 2021 - 10:45 PM
In situations like this I'd strongly recommend a power probe to aid diagnosis. I honestly don't know where I'd be without mine (spend the extra for the one with the small screen for voltage readings.)
Posted 04 March 2021 - 12:20 AM
Some looms power the rev counter off the same fuse. That could bring it 12v if there's a short with the dash illum. The screen washer pump is also run off the same fuse, does it work normally?
Posted 04 March 2021 - 08:25 AM
Which one have you got Cal?
Posted 04 March 2021 - 08:32 AM
I did add a loom to move the dials to the centre pod from the two behind the steering column. Perhaps ive crossed something in there. The washer jets work fine as do the wipers. Its just the park thats the problem.
Any thoughts in the switching appreciated.
Posted 04 March 2021 - 10:10 AM
Which one have you got Cal?[/quote
They've shot up in price, pre brexit these were around £80. I use this one.
https://www.amazon.c...wer pp03&sr=8-4
If the link doesn't work search amazon for
Powerprobe PP319FTCBLK Power Probe III - Black Circuit Tester
Edited by cal844, 04 March 2021 - 10:14 AM.
Posted 04 March 2021 - 11:52 AM
Are the connections on the park switch in the right order? The middle connector is earth, the ignition feed is furthest from it on the bottom and the connector between them is feed to the stalk via the park switch. Sounds like it could be worth a try to run a temporary live feed. If that gets it working investigate what's going on with the connections from the fuse.
Also, does the flick wipe work normally? The stalk can be reassembled incorrectly, but I can't see how that would explain the lights on weirdness.
Posted 04 March 2021 - 12:44 PM
Regarding the flick wipe. I'm not sure that is working. I have 2 speed wipers up and up on the stalk and washers push on the end. That's all it seems to do. I presume you mean if I push down on the lever from the neutral position it should wipe once and stop? it doesn't so that may be an issue. if that was working I could forget about intermittent wipe.
As I said I'd like to replace the stalk with toggle switches perhaps an off/on/on for the speeds and a seperate momentary on for the washer. Anyone have a wiring diagram for that?
Posted 04 March 2021 - 01:09 PM
Yes, that's what I meant.
Pretty sure you'll find a wiring diagram. Lots of kitcars and more "luxurious" BL models for inspiration, like MGBs. You'd want a 3 poles & throws on a generic switch - Park, 1st speed, 2nd speed. I'm sure there are purpose made ones, including in all styles of original Mini switches.
Posted 04 March 2021 - 01:40 PM
if it helps, here's a photo of the (2 speed) wiper connector i took before i overhauled it to make sure i put everything back in the right place
Posted 04 March 2021 - 01:52 PM
Posted 05 March 2021 - 05:13 PM
However the single wipe when you push down on the wiper stalk doesn't??? I suspect that is a faulty stalk. they don't seem to be great quality.
Had a good day because I also traced the flash fault to the stalk for the lights. The small brass tab that touches together when you pull the stalk is loose. I glued a tiny bit of heatshrink behind it which pulls the tab forward by no more than 1mm. All good lights flash.
Thanks everyone
Posted 05 March 2021 - 09:47 PM
