Remote Central Locking / Keyless Entry Kit That Will Work With Rover Fob
19 replies to this topic
#1 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 07 March 2021 - 07:02 PM
Hi,
I like the idea of being able to unlock and lock my Mini remotely with the Rover fob, I've had a look online and seen a few kits and read a few threads, but I'm still not sure how/if it's possible to use the Rover fob with it.
I've seen that A-Series Spares used to have a more mini focused kit, but they seem to be long gone.
Thanks for any info.
Edited by joekenton, 07 March 2021 - 07:09 PM.
#2 Deeppockets
Deeppockets
  • 103 posts
Posted 08 March 2021 - 12:56 PM
The 5AS unit has 'CDL Motor Lock' on pin 13 & 'CDL Motor Unlock' on pin 11 which drive the door locks on Rover 25/45/MGFs.  Tested this on the bench with a spare unit but have not tested with the in-situ 5AS, both present +ve active for ~1s on change.
Additional pins can be added to the connector in the car - Andrew Revill has a posted a lot of research into the 5AS for his Caterham and has detailed the connector specs: andrewrevill.co.uk/5ASConnectors.htm.  Looking at the R45 wiring diagrams, the wire spec is "0.75D" which translates to 0.75mm2  single core DIN.
Edited by Deeppockets, 09 March 2021 - 12:24 PM.
#3 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 08 March 2021 - 08:36 PM
Additional pins can be added to the connector in the car - Andrew Revill has a posted a lot of research into the 5AS for his Lotus and has detailed the connector specs: andrewrevill.co.uk/5ASConnectors.htm.  Looking at the R45 wiring diagrams, the wire spec is "0.75D" which translates to 0.75mm2  single core DIN.
Ok wow I don't even know what the 5AS is, I was hoping there was a kit I could use which would be fairly simple to wire in.
#4 Deeppockets
Deeppockets
  • 103 posts
Posted 10 March 2021 - 09:55 AM
You may want to check out John Brown's blog where he retrofits central locking to a LR Defender: DiscoverThat - Journal: Central locking PoC
Although his Defender uses the Lucas 10AS immobiliser I believe they are  in many ways similar in operation. He is using aftermarket lock actuators.
The question is whether the 5AS has the CDL outputs enabled on the Mini by default - I have not tested this (anyone know? ), if not then diagnostics/programmer would be required to enable it or replace the 5AS with a unit from a Rover/MGF.
#5 pete l
pete l
  • 1,407 posts
Posted 10 March 2021 - 10:02 AM
I think the difficult part would be finding a central locking motor small enough to be used in a mini door.
Any ideas what could be used ?
#6 Quinlan minor
Quinlan minor
  • 1,218 posts
  • Local Club: LSMOC
Posted 10 March 2021 - 11:03 AM
I've got the Central Locking Kit, Mini Spares used to supply, fitted on my '98 MPi.
It's been on the car for more than ten years/35,000miles.
Came with an "Interface Kit" that allowed it to be triggered by the standard immobiliser key fob.
It uses standard, five-wire door-lock motors that fit, no problem.
Edited by Quinlan minor, 10 March 2021 - 11:05 AM.
#7 joekenton
joekenton
  • Just Joined
  • 39 posts
Posted 11 March 2021 - 01:12 AM
So you can still get the alarm interface, I just need to find where I can get the SPI/MPI specific central locking kit. I will email Mini spares and see what they say.
#8 Quinlan minor
Quinlan minor
  • 1,218 posts
  • Local Club: LSMOC
Posted 11 March 2021 - 08:28 AM
http://www.minispare...al locking.aspx
But it seems that they no longer stock the MSSK2004 kit which has the lock/unlock lever mechanisms.
Edited by Quinlan minor, 11 March 2021 - 08:41 AM.
#9 Deeppockets
Deeppockets
  • 103 posts
Posted 11 March 2021 - 11:53 AM
Looking again at John Brown's Defender build he put the motor 2-wires between the 'CDL lock' & 'CDL unlock' outputs of the 10AS (which are pins 2 & 3 of his smaller green connector). Also wired the driver's door lock switch to 'Drivers sill - input' on pin7 of the 10AS larger grey connector.
For the Mini's 5AS unit, the equivalent pins are respectfully: 13 & 11 for the motors and 4 (SILL UP) on the large grey connector (later units also have a smaller white connector for the indicators to flash on lock/unlock).
Checking on the bench, pins 11 & 13 are both are to -ve when inactive - putting a 5w bulb across these pins lights on lock/unlock (current reversal).
For internal driver's CDL operation, referencing the Rover 45 manual:
Door latches - General
Each door has a sill button attached to the latch
mechanism. The sill buttons remain accessible in
the locked and unlocked conditions. The driver’s
door sill button when pressed, will lock all doors.
Pulling the driver’s door sill button upwards unlocks
all doors. Operation of any passenger door sill
button will lock or unlock the individual door only.
Needs more bench testing as I have been unable to get it to work as yet - pin 4 SILL UP, pin 19 SILL DOWN, both to -ve when active.
Edited by Deeppockets, 15 March 2021 - 02:58 PM.
#10 Deeppockets
Deeppockets
  • 103 posts
Posted 12 March 2021 - 02:17 PM
A quick update, I have tested pins 11 & 13 across a 2-wire lock motor (from a Peugeot 107) and can confirm the output is more than adequate to drive the motor - lock & unlock  Hopefully I will get a chance to check the sill switch lock/unlock function over the weekend.
Edited by Deeppockets, 12 March 2021 - 02:23 PM.
#11 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 12 March 2021 - 07:52 PM
Same system that I’ve been using for 5 years with no problems at all.  Would recommend it.
#12 Carlos W
Carlos W
  • 10,114 posts
Posted 13 March 2021 - 12:43 PM
Those door lock motors are readily available online
#13 surfblue
surfblue
  • 1,827 posts
Posted 13 March 2021 - 02:07 PM
Just use the door key!
It's part of an old car's charm. I have central locking and keyless start etc on my modern car, more than happy to use an FS key on the mini.
#14 MikeMPi1999
MikeMPi1999
  • 47 posts
Posted 15 March 2021 - 02:15 PM
Hi, Ive actually done a few videos on this that might help.
https://youtu.be/0iXrFk-hB_I
M
#15 Deeppockets
Deeppockets
  • 103 posts
Posted 16 March 2021 - 04:31 PM
Good work and good luck with your resto of Timmy.
Thinking about keyless entry and start, my 1970 Clubman had both - just a screwdriver was all that was needed.
Edited by Deeppockets, 16 March 2021 - 05:51 PM.
