Mpi Engine Use In Another Mini?
7 replies to this topic
#1 R32Egor
R32Egor
  • 313 posts
Posted 11 March 2021 - 06:19 PM
Hi all,
Can you use an MPI engine (1997)  in a 1992 1.3carb mini as in just before SPI?
#2 Tones61
Tones61
  • 434 posts
Posted 11 March 2021 - 06:26 PM
There is NO distributor or hole in mpi block,so would need a stand alone ecu,or the full mpi ecu/set up :-)
#3 nicklouse
  • 18,697 posts
Posted 11 March 2021 - 07:35 PM
Basically you can use any Mini power unit in any Mini but you will need to make suitable avomodations for what is there and what is not.
so you could put the complete MPi set up into a older Mini but you would need a new ignition set up or use the whole of the MPI fuelling and ignition. And suitable parts to revert back to a side Rad.
#4 mab01uk
mab01uk
  • 12,538 posts
Posted 11 March 2021 - 10:51 PM
Brian Gunn charts the process of fitting an MPi engine to his 1983 Mini:-
https://www.aronline...mpi-conversion/
#5 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 12 March 2021 - 04:02 PM
This was early in the installation
Attached File  Smith 022.JPG   75.37K   2 downloads
#6 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 12 March 2021 - 04:04 PM
Another alternative
Attached File  HDES3067.JPG   61.13K   1 downloads
#7 orcadian
orcadian
  • 203 posts
Posted 13 March 2021 - 05:21 PM
I put a 99 MPI unit in my 70's Clubman Estate about 12 years ago but I used all of the wiring/ECU/5AS stuff from the crashed John Cooper LE. Still going strong with no issues. I made my own adaptations to the flat van type petrol tank to house the pump - should be much easier in a saloon as the MPI tank is a direct fit. You will also need extra fuel pipes - feed, return and vent.
http://www.stallard-...ubmanestate.htm
Quite a few parts to the story
#8 R32Egor
R32Egor
  • 313 posts
Posted 17 March 2021 - 02:16 PM
Thanks to all for the information
