Hi all,
Back again. I have to remove my fuel tank, but can't quite figure out how to get to the required bolts.
I have already drained the tank. I have misplaced my trusty Haynes so can't quite look it up until I dig it back up haha.
My fuel tank hasn't been installed quite right by whoever installed it many moons ago, the fuel tank strap doesn't sit in the recess for it across the tank, and the strap seems to be bent quite creatively in order to get the tank secured.
The bolt at the bottom by the light cluster I can't reach, not even with needle nose pliers, they won't fit in the space between the strap and the bolt, and the bolt that goes into the rear "bulkhead" behind the rear seats is not really reachable unless I suddenly grew rubber arms or something. I tried pulling the rear seats and see if I could undo it from the interior side, but it seems it is a welded on nut that the bolt treads into. How do I remove the fuel tank, or rather the bolts that hold the tank strap in place?
I have a new rubber neck seal and foam ring, as well as a new cage nut and new strap ready to go in too, so I can fix it properly now.
Thanks guys!
