When my classic Mini's were used as daily drivers I always used to fit Yale M69 Car/Van Security Deadlocks to both doors (half way down) and the boot, (as did companies like Wood & Pickett to their expensive coachbuilt Mini conversions). They were easier to fit to sliding window doors but could also be fitted into winding window doors if you were careful to avoid interfering with the glass drop area/channels.
Van security companies were fitting them until recently, not sure if the Yale or similar car/van security locks are still available today?
Originally designed by Yale, the ‘M69’ is well-known within the security industry, where it is used to provide additional protection for motor vehicle doors. There are five lengths of lock cylinder to suit different door thicknesses, fitting into LH and RH standard cases. This lock was once fitted as original equipment to Rolls Royces.
Operating bolt throws into striker in door post, and is held positively by action of lock cylinder.
Key is turned through 360° to throw and withdraw deadbolt. Keys can be withdrawn in either mode. Bolt withdraws fully flush into case.
With components separated, case is sunk into door-edge, mortice fashion. Cylinder is inserted through aperture cut in door panel and is engaged into top face of case. It is then screwed fully into position using two holes in lock face. Finally, set-screw on flange is tightened, and pegs may be driven into face to seal fixing holes. Striker is fitted to door-post, and a trimescutcheon is provided.
Brass pin-tumbler lock with up to 1000 combinations. Unshuttered. Brass keys, nickel plated in ‘SX’ series
Chromium-plated throughout.
Lock and cylinder are brass, case is zinc diecast with steel cover plate and brass extruded bolt. Steel striker and escutcheon.
Standard key cylinder
Available as pairs/sets
Edited by mab01uk, 22 March 2021 - 05:29 PM.
