Coolant Air Lock? No Heat In The Car And No Temp Gauge Movement
12 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 13 March 2021 - 05:09 PM
Hello
1993 L reg SPI Cooper
I have replaced the following
  • coolant hoses
  • radiator
  • water pump
  • thermostat
  • thermostat housing
  • heater matrix
  • water temp sensor
  • Air temp sensor
  • Lambda sensor
  • TPC thing
  • Probably other things I can't remember
I've also had the inlet manifold vapour blasted and refurbished by Roger Carpenter
Yesterday, I filled up the coolant system
I expected trouble
I expected air locks
No heat in the car or reading on the temp gauge
I have squeezed all accessible hoses
Repeatedly
I have disconnected the heater hoses into and out of the car, in the engine bay and filled that up where the hoses looked dry
Reconnected
Engine on
Dash temp gauge still shows no temperature at all
The needle doesn't move
Nothing
I have tried the "big funnel" method to give the coolant more volume and a higher head to expand up into
It does expand up into the funnel
Engine off and the levels subside
While the engine is running, increasing the revs causes the coolant level to drop slightly
Turning the engine off causes levels to temporarily rise / surge
Still no heat in the car or any reading at all on the temp gauge
Any ideas / suggestions before I opt for Basil's Fawlty small branch and the damned good thrashing option?
Are there any after market coolant hoses with built-in bleeding valves?
There must be an easier way!
Thanks in advance
#2 genpop
genpop
  • 531 posts
Posted 13 March 2021 - 05:32 PM
Disconnect hose from thermostat and close with some cork.
Open the radiator cap. Close heater valve. Push some air into the hose or connect to water hose.  Water should poor out of the radiator. inlet manifold is free possibly socket not connected to coolant temperature sensor.
if no--> intake manifold clogged.
Opne heater valve and squeeze the hose to the inlet manifold.
Same procedure
water pooring ----> heater matrix ok
no water----> valve does not open or matrix clogged
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 13 March 2021 - 06:18 PM
The inlet manifold has been vapor blasted and refurbished
It's as new
Better than new
It's not clogged
The water temp sensor on the inlet manifold is also new and firmly connected
I will try the hose disconnections and squeezing
Although the heater matrix was new last year, it could be clogged up with crap
The inlet and outlet hoses to and from the heater matrix.....is there a bypass or does all water in, run through the matrix and out the outlet hose?
#4 genpop
genpop
  • 531 posts
Posted 13 March 2021 - 06:25 PM
Just test it. I had new silicone tubes mounted and then the inlet manifold was clogged with some celophane.
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 13 March 2021 - 06:28 PM
I've disconnected the hoses into and out of the engine bay
The hoses that run into and out of the heater matrix
Clean water in
Clean water out
Not under pressure
A funnel and a jug of water
Suggests the matrix is clear to me
Unless there's a bypass part of the matrix
But then, that would render the matrix useless, so i assume there isn't?
#6 genpop
genpop
  • 531 posts
Posted 13 March 2021 - 06:51 PM
No bypass known!
What about your thermostat. I know about users they had put it in in wrong direction!
#7 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 13 March 2021 - 07:33 PM
Wrong direction?
That's a possibility
Didn't realise there was a wrong direction
Something else to check
#8 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 March 2021 - 05:20 PM
Simple update
All advice was gratefully received
Including outside / off the Forum from Roger Carpenter (the inlet manifold wizard.....and knower of many, many things)
I reinstalled the thermostat
I had in sitting directly on / in the top of the engine block
It's now on the sandwich plate where it should be
I found a radiator overflow tank I didn't know was there
I topped it up with coolant
I systematically opened up and reconnected a few hoses, poured water / coolant into them
Water / coolant came out where it should to show there were no blockages in the matrix and / or the inlet manifold
All refilled, radiator cap tightly on
I started the engine
I left it running at idle for c5 mins then upped the revs to 2-3k for a couple of minutes
Heat in the car and a working temperature gauge
Hooray
Thank you, you wonderful people
#9 Tornado99
Tornado99
  • 750 posts
Posted 14 March 2021 - 05:34 PM
So the only found issue was upside down tstat? I always test them in boiling water when new to ensure they open fully.
Did you say you "filled" the overflow tank? That sounds wrong as it should only get volume when coolant over pressurizes, then gets sucked back into system as it cools. Having it pre filled means no where for excess to move to.
Edited by Tornado99, 14 March 2021 - 05:35 PM.
#10 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 March 2021 - 05:44 PM
The stat was the right way up, but it was in the wrong position
I know the stat was ok because it was new not long ago and it was working in the car until relatively recently
I wondered the same about the expansion tank, but it was advice given (and gratefully received) from elsewhere
With nothing else working, I tried it
I don't know whether it was part of the solution or a new problem waiting to bite me later
I didn't completely fill the expansion tank, but I did pour some coolant into it down the expansion hose
Following the advice below
The other thing you need to get right is the expansion tank, which fits under the wheel arch and is fed off the radiator.
That's an essential part of the cooling system.
What isn't stated anywhere is that there needs to be coolant in the expansion tank when fitted
Doing so allows the cooling system to hit an equilibrium and it'll draw back cooling water etc as intended.
#11 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 March 2021 - 06:02 PM
Red is wrong
That's where I had the thermostat
Now in the green location
Foolish me
Attached File  thermostat right and wrong March 21.png   425.9K   6 downloads
#12 genpop
genpop
  • 531 posts
Posted 14 March 2021 - 07:01 PM
When I remember right, red has no milling bevel  so it is wrong in all cases!
But good that you could find the problem.
#13 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 14 March 2021 - 07:32 PM
There's a bevel to receive and locate the thermostat on the engine block AND in the sandwich plate
Just to confuse buffoons like me
And it worked!
