I am about to get back to tackling a clutch issue from a couple years back.
Pulled the engine and removed clutch , flywheel, transfer case etc.
Issue was the car had been very hard to get into gear for ages.....and could not really stay at a traffic light with car in geard and clutch in All pivot points were good, new slave, master, hose, plunger, arm etc.
Anyway... My feeler gauges only got to .005" and I can't really get it in there to check the end float...what should it be?
Also.....I took off the thrust washer to measure it with the calipers THAT I CAN"T FIND, and can't remember which way around the thrust goes back on.
Also....what is the stock thickness
Pictured
I've not driven this car for 2 yrs now.....and it's a shame. Strong 1130 A series ...pre verto
Sorry for the long winded simple question.......frustration.......
