Won't Start Again Once Warm
Posted 15 March 2021 - 06:54 PM
Posted 16 March 2021 - 10:12 AM
You don't state your Mini year of make.
Failing that - if you have a carburettor - do you have oil in the dashpot ?
Posted 16 March 2021 - 10:32 AM
Where did you check the spark?
Ht leads points or where? Could be dizzy cap/rotor arm.
I would also check the negative under the engine mount below the master cylinder. Have seen them loose connection causing your issues..
Posted 16 March 2021 - 11:14 AM
Oh yes it's 1990 city e. 999. Yes there's plenty of fresh oil in the dash pot.
Posted 16 March 2021 - 11:17 AM
Posted 16 March 2021 - 11:19 AM
Any smoke issues?
There's no issues with smoke, I checked the spark at the plug attached to the HT resting on the Block. I do have a sparkrite sx2000 spark booster module clamped to my coil. I'm going to remove this and see if it remedies the issue. I'm tempted to remove the points system and fit an electronic ignition but I want to sort out any underlying issues first. To add to the complications I wasn't getting much fuel to the plugs when turning over. I'm wondering if this is another separate issue with the fuel pump, but that wouldn't really explain why it restarts once cooled down again
Posted 20 March 2021 - 04:40 PM
Posted 22 March 2021 - 10:39 PM
Posted 22 March 2021 - 10:40 PM
