Why Have The Washer Bottle Inside Cab?
13 replies to this topic
#1 babsbrown
babsbrown
  • 592 posts
Posted 20 March 2021 - 01:03 PM
I've noticed on a few rally Minis that the washer bottle is inside the cab. What's the reasoning behind this? I was thinking incase of a crash water isn't sprayed all over the electrical components? Cheers, babs
#2 whistler
whistler
  • 1,898 posts
Posted 20 March 2021 - 02:44 PM
I would suggest to stop it from freezing, larger capacity and easier to fill up.
#3 Avtovaz
Avtovaz
  • 1,316 posts
Posted 20 March 2021 - 04:26 PM
its for weight distribution, and also, less stuff in the way when your taking the engine out etc.
#4 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 20 March 2021 - 04:46 PM
And if on a long stage you can see how much water you have left, so you dont over use it before the end of the stage, and of course less chance of it being hit by a stone and ruptured inside the car..
#5 babsbrown
babsbrown
  • 592 posts
Posted 20 March 2021 - 10:50 PM
Cool thanks guys, im replacing the washer bottle at the minute and contemplating taking it inside the cab
#6 Ethel
  • 26,814 posts
Posted 21 March 2021 - 11:32 AM
Saves you having to stop for the loo on long stages  :X
Used to be common in military & commercial wagons too.
Helps prevent freezing, allows for a bigger tank and  means you can keep an eye on the level & top up easily.
#7 Cooperman
  • 23,569 posts
Posted 21 March 2021 - 02:31 PM
Mine is mounted by the navigator's feet on the wheel arch and at floor level. The twin electric washer pumps are mounted right above the reservoir with an additional switch on the navigator's panel. Fuses for the pumps are also on the navigator's side and each pump has its own fuse.
Thus it is convenient and reliable and one less system in the already crowded engine bay.
#8 babsbrown
babsbrown
  • 592 posts
Posted 21 March 2021 - 11:24 PM
Thanks chaps, is there any hard and fast, and reliable way to fasten the reservoir in?
#9 nicklouse
  • 19,067 posts
Posted 21 March 2021 - 11:39 PM
The existing bracket works well enough. You might want to add something to reduce the chances of it lifting out. But nothing was needed in the original position.
#10 babsbrown
babsbrown
  • 592 posts
Posted 22 March 2021 - 11:13 AM
Cool, thanks mate
#11 Ethel
  • 26,814 posts
Posted 22 March 2021 - 12:35 PM
You could use  a bog standard 5L plastic container drill a hole in the cap for the feed hose, stick a non return valve on the end & mount the pump(s) to the body. It'd then be easy to take it out to refill, give you an emergency water supply for the radiator....
#12 babsbrown
babsbrown
  • 592 posts
Posted 22 March 2021 - 10:51 PM
Ah great idea! I did manage to source a big tank, just need to make some fixing brackets
#13 DEPS
DEPS
  • 188 posts
  • Local Club: Carlton & District Motor Club
Posted 23 March 2021 - 10:29 PM
I had the standard plastic bottle moved to co-drivers footwell many years ago for all the above mentioned reasons and it worked well .
When the under-wing washer bottle got ripped out of my Peugeot 106 Rally car on a rough stage we replaced it with a bag type from Car builder solutions and we found that to be very good as light and the pump was at the bottom of the bag. This meant the pump did not have to work too hard sucking the water out of a bottle.
What I have discovered of late is that the mini washer pumps that you buy these days seem very poor quality and we are forever having problems with them on our road mini come mot time!
It is therefore our intention to fit the bag type when we get to that point in our mini rally car build
#14 OzOAP
OzOAP
  • 401 posts
Posted 07 April 2021 - 09:10 PM
We ran one in car so it could be bigger.
