Installing New Brake Master Cylinder. Any Tips?
3 replies to this topic
#1 babsbrown
babsbrown
  • 582 posts
Posted 22 March 2021 - 11:18 AM
Morning guys , I'm renewing the brake master cylinder on my 1990 city e. This is because I had brake fluid leaking into the servo. If it still leaks I will replace the servo too. I was just curious if anyone has any tips that will make the job any easier when it comes to rebleeding the system? Or fitting the new cylinder. I was tempted to fit the braided hoses for easier manoeuvrability of the servo in the future,but I'm not overly convinced I will get a good seal on the banjo fittings especially when the master cylinder is designed for a tapered union. Thanks in advance, Babs
#2 panky
panky
  • 1,837 posts
Posted 22 March 2021 - 11:34 AM
Pre-bleed the new master cylinder before you fit it to get any air out. Put some fluid into the reservoir and pump the plunger a few times until the fluid squirts out (into a rag) and put the blanking plugs back in until you're ready to re-connect the brake pipes.
A bit messy but it helps bleeding the system one it's fitted.
#3 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 22 March 2021 - 01:48 PM
personally if your changing it, bleed the system fully anyway, i havnt ever had an issue's plus its fresh fliud all round.
#4 babsbrown
babsbrown
  • 582 posts
Posted 22 March 2021 - 10:36 PM
Brilliant exactly what I needed, cheers guys
