Wheel Spin Issues - Where To Start?
9 replies to this topic
#1 Jfcrouch72
Jfcrouch72
  • 34 posts
Posted 23 March 2021 - 03:06 PM
Sorry for the vague title and info here...but not sure where to start.
What can cause excessive wheel spin?  Reason for asking is that up until recently I never really experience much wheel spin, and now it's all gone a bit pear shaped.
I used to be on Yoko 32's....the car would handle perfectly and I had a lot of confidence driving it.  I then decided to get a set of spare minilites that i had refurb'd and a set of Blockley tyres put on.  Shortly afterwards, the car went in for a checkup and one thing that was noted was it was handling really poorly although they didn't mention anything about wheel spin.  The garage then spent a while working on the whole geometry settings etc until it was better.
However. once all done and dusted I noticed it now wheel spins like crazy..I even put my original set of minlites back on with the Yoko 32's...a bit better but still wheel spins.
So...I'm left with a car that supposedly has had it's geometry all checked and 2 sets of wheels both of which are giving me wheel spin.  The car does handle much better...just this damn spinning.  Nightmare at junctions...people must think i've got a right issue.
I'm running on a 1310, 3.73 FD.  Last checked out on a rolling road @104bhp at the wheels.  I don't think this makes much difference as the spec is the same when I 'didn't' have these wheel spin issues.
Am i missing something here?
James
#2 I hate Brian
I hate Brian
  • 782 posts
Posted 23 March 2021 - 03:10 PM
Hi what setup you running to get 104 bhp at the wheels ?????
#3 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 23 March 2021 - 03:11 PM
Did they tell you what they set the Camber / Toe too?
#4 imack
imack
  • 2,372 posts
Posted 23 March 2021 - 03:40 PM
Was it corner weighted?
#5 sonscar
sonscar
  • 3,198 posts
Posted 23 March 2021 - 05:13 PM
Broken damper,collapsed suspension causing three wheeling?Look at the rear first would be my call.Steve..
#6 Tones61
Tones61
  • 440 posts
Posted 23 March 2021 - 06:35 PM
Tyres are everything,get some more Yokos :-)
#7 Jfcrouch72
Jfcrouch72
  • 34 posts
Posted 23 March 2021 - 06:53 PM
thanks for the replies so far.....
so just for a bit more info (base on some of the questions come back to me).
setup is 1310 A serie.  weber 45. Swiftune SW8 cam.  x-pin diff. 3.73 Final drive. Swiftune/CSI electronic distributor.
I don't have the camber/toe info to hand...but I can get that from the garage.
not corner weighted..never has been (and never had issues until now).
broken damper - no.  These were recently checked.  I'm running Spax adjustables...might be worth double checking those and making some adjustments down there to help?
Definitely no suspension collapse...all 4 wheels are definitely where they should be.
more tyres - yep.  Probably a good shout there.  Admittedly, when i put my old Yokos back on, the wheel spin did reduce and was better than the Blockleys.  Perhaps a new set of Yokos would do the trick.  thanks
#8 Tones61
Tones61
  • 440 posts
Posted 23 March 2021 - 06:56 PM
What's the head spec and comp ratio dude,that's a LOT of power,
Nice spec though :-)
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 March 2021 - 07:30 PM
Get it corner weighted and a full suspension set up. You'll probably find it's just the compound change on the tyres and the engine being run in
Also try different ways on the clutch
Edited by cal844, 23 March 2021 - 07:35 PM.
#10 Spider
  • 15,684 posts
Posted 23 March 2021 - 07:49 PM
If it's the same wheel that spins every time, then as Imack alluded to, your corner weights will be out.
Most I've found with this issue have Hilos in the front. Looking at how they had been adjusted / set, it was clear that one of the cones had collapsed.
