Specialist Components Idle Air Control
7 replies to this topic
#1 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 25 March 2021 - 02:27 PM
A few months ago, someone mentioned they were adapting idle air control to an SC setup.
Just wondering if any progress has been made.
Terry
Edited by tmsmini, 25 March 2021 - 04:52 PM.
#2 Wazzah
Wazzah
  • 142 posts
Posted 25 March 2021 - 09:36 PM
Hi Terry,
I seem to remember that someone was adapting the MPI IAC for the SC set up.
The challenges I see would by modifying the throttle body or inlet manifold with a port to accept inflowing air.
There is an airflow adjustment on the top of their TB which could be utilised.
I used an SU sandwich plate with a vacuum port in it for other purposes so perhaps this could serve as a port.
The SX Tune software has the necessary functionality for IAC and stepper motor control but it's an entirely different matter whether the Delta 400 ECU has the matching capability to run these functions.
SX Tune has lots of stuff that the Delta 400 can't handle.
Regards Waz
#3 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 25 March 2021 - 10:22 PM
The D400 doesn't have outputs for IACV. I've had this argument with SCS about their overly expensive 'entry level' ECU.
#4 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 25 March 2021 - 11:27 PM
SC really need to address this as an IACV is absolutely needed for a daily driver using their system.
Mine has one fitted after Chris at EFI-Parts pretty much insisted on it and there was a world of difference. I also binned their ECU and used an Adaptronics ECU and a custom loom made by Chris.
#5 Midas Mk1
Midas Mk1
  • 5,778 posts
  • Local Club: S.U.N.M.C
Posted 25 March 2021 - 11:40 PM
I’ve done 4 years without an iacv, literally once off cold start enrichment it’s fine, nothing different to using choke imo.
#6 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 27 March 2021 - 04:31 PM
I too have been running with out an IACV for a few years. I am not sure that the system would not run better with one. It seems that an IACV might contribute to better overall running. Our cars are daily drivers, so they need to run well in a variety of conditions.
One issue I have had is getting the engine to temperature with around town driving. I have switched to a 205/96 thermostat which has helped as the engine maintains temparature. I am using an MPi block, so colling may vary. Using the 190/88 thermostat, themp would barely get above 176/80. I could modify the cold enrichment map, but modern fuels seem to burn better at higher temps.
Actually the first SC setup I bought used and the TB had been modified to take an IACV perhaps. I got no information or additional parts with it, just a plug for the hole.
The throttle quadrant on the TB was bent and when I inquired with SC about gettings parts, I was told they no longer supported that version. So I never attempted to use it. I did eventually straighten the bent parts, but I have never used it.
It seems like it is time to get the MicroSquirt system out and create a loom for the SC TB components.
#7 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 27 March 2021 - 06:31 PM
It seems to me a better location would be the servo port on many of the later maniolds. In the US DIY Autotune sells an IACV adapter kit that could be adapted.
I always assumed the IACV functions were in the D400, but just not enabled in the configurations provided for the A series.
#8 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 01 April 2021 - 12:42 AM
Remember sxtune covers off their entire range of ECUs.
Like the idea of the port on the side. My inlet manifold will have the port for IACV, however i must be cognisant that it will try and run lean at cold idle with it open!
