Steel Wheel Damaged- Usable/normal?!
Posted 28 March 2021 - 01:33 PM
A while ago I purchased some 10 inch steel wheels as the plan is to change mine from 12 to 10
Didn’t check the wheels when they arrived and thought I’d take a look today as I have a week off work so could order parts and look to get the mini on the road for the summer... however! 2 of the wheels have a little chunk missing and 3 round knob type things on them... I haven’t ever paid enough attention to know if this is normal as the missing bits have been painted over so I assume we’re used like this... my head tells me that a missing bit of wheel isn’t great but I’d appreciate your knowledge!
2 wheels look normal
2 have almost identical little chunks missing
Posted 28 March 2021 - 01:58 PM
I do not believe that chunk missing is normal at all.. I have never seen them like that, and they may well be dangerous and possibly an MOT failure.. they may be ok on the rear I would not be happy with them on the front though
Posted 28 March 2021 - 02:26 PM
Hi Chris
Personally, I wouldn't like to use them wheels, never seen anything of the sorts
How the devil that is damaged like that ??????
Be good to get some other members views
Neil
Posted 28 March 2021 - 02:29 PM
Description says slit in centre bore for trailer.
So I assume at some point these wheels were used for a trailer.. not sure what the slit would achieve on a hub...
any idea what the 3 knobby bits are all about
(Photo is a random eBay listing and not my wheels)
Posted 28 March 2021 - 02:30 PM
Posted 28 March 2021 - 02:44 PM
My first thought was trailer wheels too.
It does look like the slots could've been ground in a Mini wheel, but I don't recognise the round bosses either.
Any stamped in narkings & have you worked out what the offset is?
Posted 28 March 2021 - 05:26 PM
No obvious markings or stamp on the wheels that I can see. Not sure on offset but the tyres fitted are 145/80/10 if that helps
Posted 28 March 2021 - 05:31 PM
Posted 28 March 2021 - 05:42 PM
I reckon they're Mini wheels, but measuring the offset would give you something to compare. Might be a clue on the back if the bosses are added, can't imagine them being original when there are Mini style pressed in hubcap lugs.
Cant see anything critical being effected, but you could weld up the slots.
Posted 28 March 2021 - 05:54 PM
Three bumps are for hubcaps slots have been cut with a grinding disc as said for a trailer.Do you feel lucky?I would find some more.Steve..
Thanks, I think I’ll shove them on the back. Or before I take it for the MOT I’ll take the wheels to the garage and see if they consider it a pass. Obviously with the hub caps on they won’t see and technically shouldn’t remove the hub caps to check but I’d prefer me and the mini to be safe! A blob of weld ground to shape sounds like a good peace of mind plan if I stick with these wheels
Posted 28 March 2021 - 06:32 PM
It's hard to see how they'd see any stress inside the pcd of the studs, but no accounting for how a tester could apply the rules. If you're swapping from 12's - you're aware the wheel nuts changed with later 12 inch steelies?
http://www.minispare...sic/88G322.aspx
Posted 28 March 2021 - 06:54 PM
Thanks, didn’t know that! Assumed a wheel nut was a wheel nut! Shall add these to the shopping list
Posted 31 March 2021 - 08:05 AM
