Fuel Gauge Only Reading 3/4 When Full
8 replies to this topic
#1 Steve66
Steve66
  • 67 posts
Posted 03 April 2021 - 08:53 AM
Hi all,
Sorry if this has been covered elsewhere - I can't find an answer
My Mini fuel gauge will not read correctly.  Only goes to 3/4 when full.
I have tried 2 new sender units (out of the tank) and both are the same. I have also tried a different sent of clocks and that only reads 3/4 when full.
If i short  the wires out both sets of clocks show full.
Runing out of ideas - can anyone suggest anything please
They are the 3 clock Nippon seiki type
I don't know if the temp gauge is accurate but it does show hot if shorted
Steve
#2 FDW
FDW
  • Just Joined
  • 49 posts
Posted 03 April 2021 - 09:02 AM
Got a similar thing on mine, 3/4 when the tank is full and when it gets into the red I tend to have about half a tank actually left... I'm well accustomed to it now but on the to do list somewhere
#3 Steve66
Steve66
  • 67 posts
Posted 03 April 2021 - 09:14 AM
That is probably the sender wire wants adjusting. Mine reads ok when empty so is something to do this calibration but I don't know how to check
#4 Tornado99
Tornado99
  • 750 posts
Posted 03 April 2021 - 06:21 PM
Can you use a mirror and light or a cheap borescope to see if the float or arm is getting stuck against someplace when trying to float up fully?
#5 Spider
  • 15,136 posts
Posted 03 April 2021 - 07:12 PM
As Tornado suggests, the Arm will likely be getting stopped on the Filler Pipe, in the later tanks, they extend a fair way in to the tank to leave an an air pocket to allow for expansion, they can often foul on that.
A bit or a bend the the arm usually is all that's needed to get them to clear.
#6 Steve66
Steve66
  • 67 posts
Posted 04 April 2021 - 10:51 AM
Hi the sender is out of the tank so definitely travelling to max in both directions
cheers
#7 Compdoc
Compdoc
  • 612 posts
Posted 04 April 2021 - 04:57 PM
If all else fails, try:
https://spiyda.com/f...wizard-mk3.html
#8 Spider
  • 15,136 posts
Posted 04 April 2021 - 07:52 PM
cheers
Yes, out of the tank it will likely be fine, but it's probably fouling on the filler neck in the tank.
#9 Steve66
Steve66
  • 67 posts
Posted 05 April 2021 - 11:00 AM
Thanks for the suggestions. Third time lucky on the gauge.  So the sender was ok
Can’t believe two wrong gauges!
