I'm rebushing the throttle spindle on a HS6 and looking for the correct Loctite Green to hold the bushes into the carb body. Can anyone help with the product number please?
Posted 04 April 2021 - 06:05 PM
Posted 04 April 2021 - 06:45 PM
Could be Loctite 620 you require.
Posted 04 April 2021 - 06:48 PM
Posted 04 April 2021 - 06:56 PM
Loctite? Are they not a press fit like the HIF carbs?
Phil.
Don't have one to hand at the moment but pretty sure they're a split bush and everything I've read or watched says use green loctite to stop them moving after reaming to 9.5mm.
Posted 04 April 2021 - 07:46 PM
Posted 04 April 2021 - 07:49 PM
Edited by ACDodd, 04 April 2021 - 07:56 PM.
Posted 04 April 2021 - 07:50 PM
They normally are a press fit, however, some added insurance isn't a bad idea.
Loctite 620 or 648 would be fine.
The 620 will be more useful though in other applications.
Posted 06 April 2021 - 10:10 AM
The bushes are of the split type. From SU crk223 rebuild kit.
Hole to be reamed to 9.5mm but not all the way through to the body. Must stop before breakthrough into main orifice.
that's the instructions and also as shown in video from Joe Curto.
Edited by whistler, 06 April 2021 - 11:01 AM.
