Leaks
3 replies to this topic
#1 bloodythingwontstart
  • 11 posts
Posted 06 April 2021 - 06:27 PM
Hi all,
I've got the common issue of water getting into the car and collecting in the front footwells but I'm struggling to identify where the water is coming in. This has been happing for a while and I assumed it was the windscreen leaking but I'm having my doubts.
On the passenger side it seems to be coming in from above near the air vent and the dash top rail, you can see 2 trace marks on the pic below showing the leaks
Attached File  20210406_181438 (2)_LI.jpg   34.4K   0 downloads
On the drivers side this seems to be coming from right at the top of the bulkhead behind the speedo/windscreen vent, again you can see a mark on the bulkhead where the water seems to be coming in.
Attached File  dash.jpg   54.74K   0 downloads
For reference the car had a new scuttle and front end about 3 years ago, door and windscreen seals were also changed. As far as I can tell the windscreen panel is still in good condition and not rusted through... These are not huge leaks but in heavy rain a small puddle forms in each footwell and I'm not so keen to be having new floors put in again!! The car is a 1989 Mayfair.
Anyone got any ideas?
Cheers!
Edited by bloodythingwontstart, 06 April 2021 - 06:29 PM.
#2 imack
imack
  • 1,872 posts
Posted 06 April 2021 - 07:00 PM
It often comes in via the door check straps. Have you got the seal fitted around the check strap in the door apature?
#3 sonscar
sonscar
  • 2,724 posts
Posted 06 April 2021 - 10:28 PM
I would suspect the screen or possibly the roof to A panel join.It looks as though it is getting between the seam somewhere.Good hunting.Steve..
#4 bloodythingwontstart
  • 11 posts
Posted 09 April 2021 - 07:32 PM
Cheers guys,
The door check strap seals are present and seem to be keeping the water out, I'll have another look with the hose this weekend.
