Nut Access
6 replies to this topic
#1 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 April 2021 - 11:26 AM
Hi folk.
The subframe to sill upper captive nut, where is the best place to access it?
Ive rewelded/repaired the lower one, gone to refit the subframe and the upper one wont grab now  :mmkay:
Ive practised retorqued everything else to 25nm so hopefully once this one is fixed the subframe will be good to go in.
#2 nicklouse
  • 18,998 posts
Posted 11 April 2021 - 11:33 AM
Same place as the lower one really.
#3 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 April 2021 - 11:34 AM
Through the outer sill?
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 April 2021 - 12:42 PM
My plan is to run a small bead of weld externally from the captive nut to the heal board - just to make sure the nut is well attached.
Il then helicoil it.
#5 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 11 April 2021 - 01:10 PM
Yes mate cut a hole in the outer sill
#6 nicklouse
  • 18,998 posts
Posted 11 April 2021 - 01:18 PM
Ain’t that how you fixed the lower one?
#7 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 April 2021 - 01:26 PM
It is yes, I cut the corner out then rewelded the sleeve on whilst on my bench. Then welded it back in.
I dont like welding upside down and worried Il not get good enough access.
