Twin Hs2 Needle Query
5 replies to this topic
#1 MiniMax1984
MiniMax1984
  • 17 posts
Posted 12 April 2021 - 12:17 PM
Hi Everyone,
i am close to finishing my enginebuild and need advice with jetting the carbs. Specs:
- Twin HS2 carbs with K&N filter, Carbs were vizarded (modified piston, cut butterfly)
- ported and matched intake manifold
- LCB and bigger RC40
- ported head with 36 inlet / 29 outlet
- 1275 A+ with +0.20 dished pistons, 10.5:1 CR
- KMD 266, timed 3° in advance
- 1.5 highliftrocker
- full breather setup with catchcan
- mechanical dizzy, modified for the cam
For the Setup i do have an AEM Air/Fuel Ratio Gauge with lambda
The Carbs are new and came with a "AAZ" needle it seems.
Any of you have an idea what range the needle should be in? Or even better does someone run a similar setup?
Edited by MiniMax1984, 12 April 2021 - 02:41 PM.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 12 April 2021 - 01:31 PM
Run with them needles and see where you get to
Cooper conversion HS4 twins run with AAK AND MME
#3 MiniMax1984
MiniMax1984
  • 17 posts
Posted 12 April 2021 - 02:42 PM
My Bad, had HS4 written in the post, i run twin HS2. corrected the post.
#4 MiniMax1984
MiniMax1984
  • 17 posts
Posted 12 April 2021 - 02:47 PM
I understand that the twin HS2 on 1275 Cooper S run between AH2 (Rich) and EB (Lean) needles, correct?. According to this comparisoon the AAZ might indeed be a good start.
Attached File  Anmerkung 2021-04-12 164425.jpg   27.75K   0 downloads
#5 timmy850
timmy850
  • 2,989 posts
  • Local Club: MITG
Posted 13 April 2021 - 06:13 AM
The spring and the damper oil will also make a difference to tuning.
I’d just go for a drive and see how it goes if you have the afr gauge.
As some have mentioned before, “Vizarding” carbs can make them a bit strange on the road as you have changed the airflow balance from the stock carb
#6 MiniMax1984
MiniMax1984
  • 17 posts
Posted 13 April 2021 - 11:54 AM
Yeah but i wanted to try by myself. New pistons are quickly installed. And i might have to switch to bigger carb(s) anyway, we'll see!
