Removing The Interlock Spool, Rod Change Box
4 replies to this topic
#1 HazleNut21
HazleNut21
  • 15 posts
Posted 12 April 2021 - 02:33 PM
Hello All, back again with more gearbox questions....
I am trying to remove the interlock spool on my A+ rod change box. I have noticed there is some sort of dowl that looks to be holding it in place and stopping it from rotating around or being pulled out, do you know what this is, how to remove it, is it a permanent feature etc, I am unsure as with all the videos I have watched I have not seen it featured or mentioned, any info much appreciated. (images attached)
  • Attached File  1.jpg   19.58K   1 downloads
  • Attached File  2.jpg   24.14K   2 downloads
  • Attached File  3.jpg   15.16K   1 downloads
#2 jeffster06
jeffster06
  • 113 posts
Posted 12 April 2021 - 02:42 PM
The dowel should slide out then you can get the interlock spool out. Not sure how you get it out if its stuck though, mine pretty much fell out when I tipped the case over.
#3 HazleNut21
HazleNut21
  • 15 posts
Posted 12 April 2021 - 02:48 PM
Ah, this one doesn't seem to be sliding out! I guess I will have to see what I can do to get it free. Glad to know it does at least come out though Thank you :)
#4 KTS
KTS
  • 2,271 posts
Posted 12 April 2021 - 04:45 PM
try hooking the rubber o-ring out of the way - you may find that's holding the collar in place
#5 Spider
  • 13,929 posts
Posted 12 April 2021 - 08:05 PM
As there's not much to grab on to You can usually get them with long nose pliers, or small External Circlip Pliers, or as you have the Shifter Shaft removed, a Hook.
