Hey folks, after a very lengthy learning process, my engine is back in, all hooked up and.... not starting.
- It’s a 1275 with electronic ignition.
- I’ve got oil pressure.
- The starter motor is turning over.
- The mechanical fuel pump is working (fuel coming through the line into the HIF38 carb).
- I’ve got a spark in all four plugs (tested against the block, and checked with 2 separate coils and set of leads).
- I ‘think’ I got TDC using the plug one out, find the top point, check it’s the compression stroke by checking the rocker arms for movement, method).
- Dizzy rotor arm pointing roughly at 2pm, and leads connected to fire, anti clockwise, 1, 3, 4, 2.
- Tried the dizzy rotated slightly backwards and forwards as well.
- pulled plugs to check them again and they’re dry.
- Oh, and engine earth strap is in place.
I’m still VERY much learning, so may have missed something obvious. Carb issue? It came off for the rebuild, but I didn’t open it up or change anything...
Thanks in advance folks, and apologies if this has anyone rolling their eyes!
Anth
