Wiring Tape
Posted 14 April 2021 - 10:57 AM
Posted 15 April 2021 - 06:17 PM
I've used this when I made a wiring harness for an additional interior light on a Triumph TR7 it was fairly easy to do and looks OEM.
https://www.autoelec....uk/product/348
Edited by MikeRotherham, 15 April 2021 - 06:18 PM.
Posted 15 April 2021 - 09:55 PM
Used it on exterior and interior parts of loom and really gives smart look to the engine bay
Posted 16 April 2021 - 03:20 AM
I would actually suggest a PVC Non-adhesive tape, similar to that Mike has posted above.
I've always found in time, any adhesive tape after a while starts to slide on it's own adhesive and leaves a very sticky residue, before long they get messy and are dread to the touch.
Most factory looms of any car that are wrapped are done in a non-adhesive tape. It can give a great finish if you take a bit of time to apply it without wrinkles. To finish off an end, you can tie a neat flat knot in the material, or just melt the top layer to the under by rubbing a soldering iron over it.
Posted 16 April 2021 - 08:03 AM
...or finish off with a bit heat shrink to hold it in place
Posted 16 April 2021 - 11:03 AM
I use the PVC tape as Spider suggests and finish it with self amalgamating tape like this https://www.autoelec...349/category/68
Posted 16 April 2021 - 11:09 AM
Now that's a neat idea.
