Fuel Filter Pipe
6 replies to this topic
#1 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 15 April 2021 - 04:19 PM
Does anyone know where to get the ends for making a piece of pipe to connect to a fuel filter? It’s a 1999 MPI but the connections have been modified by previous owner.
Looking to fit M14 x1.5 heads onto a new piece of pipe to make it fit with Bosch filters.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 15 April 2021 - 04:38 PM
I used to manufacture the said pipe when we were in the UK with the correct fittings as they were NLA
I think there is a couple of places where you may be able to get some unions, one is called Clarik Engineering Supplies in Scotland
Albeit you do get the fittings, the pipe will have to be flared to avoid any leaks, and then the pipe shaped
#3 Tones61
Tones61
  • 434 posts
Posted 15 April 2021 - 05:32 PM
Buy new from minispares,all available :-)
#4 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 15 April 2021 - 06:40 PM
I have a flaring kit so will have a look see if they have what i need.
#5 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 15 April 2021 - 06:41 PM
I was going to but would mean replacing the whole lot as both ends have been changed previously.
#6 richmondclassicsnorthwales
  • 942 posts
Posted 15 April 2021 - 06:57 PM
They are a bit tricky, there is a union on one end of the original filters that sell at a silly price, 30 quid if I remember !!
The other is not so bad and needs a flare
It has to be correct - you need it spot on.  Any small drip or seepage leads to MOT failure
They are a one off line,   and when Rover went bump did not help matters.
#7 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 15 April 2021 - 07:39 PM
Somerford sell a complete pipe and filter set. Gonna get that to save aggro
