Battery Cable Mm2
8 replies to this topic
#1 RobNorway
RobNorway
  • 32 posts
Posted 18 April 2021 - 10:43 AM
Hi,
Tried looking up different posts.
What is the best mm2 cable for battery to use?
I have the options of 16mm2 and 35mm2 at the local shop.
Dose it make any difference for turbo setup?
Prefer to run the 16mm2 for the weight. 35mm2 is heavy!
Living in Norway so ordering a standard cable takes time from UK.
Thanks! :proud:
Mk1 with Mk3 1275 engine.
#2 Dusky
Dusky
  • 5,322 posts
Posted 18 April 2021 - 10:48 AM
16 is way to small.
#3 RobNorway
RobNorway
  • 32 posts
Posted 18 April 2021 - 11:23 AM
16 is way to small.
Thanks for reply. The one from minispears in 16mm2. Unless its for smaller engine.
#4 KTS
KTS
  • 2,456 posts
Posted 18 April 2021 - 01:23 PM
25mm2  would be a better option.
if you can order that and the terminals you need locally, you could make your own cable up (..would possibly be cheaper than an off the shelf item)
edit : 16mm2 should handle the current loads for starting up, but as it's thinner it has a relatively higher resistance than a thicker cable so the voltage drop at the starter motor would be greater, meaning the starter motor (..and everything else e.g coil) wouldn't be able to generate as much power
Edited by KTS, 18 April 2021 - 01:29 PM.
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 18 April 2021 - 02:32 PM
16mm will work, 25mm would be best, 35mm is a bit overkill and won’t give any advantage.
I use multi-strand ‘welding cable’ as it far more flexible and has better insulation - https://www.ebay.co....tm/203036789379
#6 RobNorway
RobNorway
  • 32 posts
Posted 18 April 2021 - 07:51 PM
Thank you for help. Much appreciated  :proud:
#7 Spider
  • 15,063 posts
Posted 18 April 2021 - 08:21 PM
The original cable, while an imperial size, is close to 16 mm2 and for 99% of Mini Builds, that would be adequate.
I use single insulated 25 mm2 in most builds, but rather than buying 'battery cable', I use a flex as it runs in much neater and is nicer to work with, though you'll probably want to get bell mouth lugs to be sure they'll be easier to get over the cable stands.
I buy mine by the drum (from RS Components), but wander down to your local welding supplies, they'll likely have it by the metre on the shelf.
#8 RobNorway
RobNorway
  • 32 posts
Posted 19 April 2021 - 12:17 PM
Thanks for the reply! Very helpful information
#9 RobNorway
RobNorway
  • 32 posts
Posted 17 June 2021 - 06:54 AM
Used 25mm2. All works good!  :proud:
