Hif44 And Cone Filter Won't Fit
engine
16 replies to this topic
#1 Moshtaraq
Moshtaraq
  • 86 posts
Posted 18 April 2021 - 12:08 PM
Hi again,
Fitted my new 1330 engine, damn that thing flies. I had to install my old HS4 from my 998 because the HIF44 won't fit. It hits the firewall.
I read somewhere that there are two types of subframes so the engine sits more in front (from SPI on?). Is there a way I can get arround this without grinding a hole in my firewall? Is a pancake filter an option?
Car is a mini 1000 from 1990
In attachement a picture of the setup:
  • minispares water cooled inlet manifold
  • spacer
  • bracket
  • HIF44
  • cone filter
Thanks,
Jens
#2 richmondclassicsnorthwales
  • 942 posts
Posted 18 April 2021 - 12:31 PM
You can swap the phenolic spacer for a thinner one. The thinner ones are 6mm thick if that would help matters
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,032 posts
Posted 18 April 2021 - 12:32 PM
Is your filter on the correct way? Seems low to me. As you said, later subframe have the engine mounting holes 1/2" further forward with longer gear linkages as well. You can may be able to get an adjustable engine steady to angle the engine forwards. You could get a thinner carb spacer/machine the current one down to gain a few millimetres.
I welded the holes and drilled them 1/2" further forwards.
#4 Readers14
Readers14
  • 439 posts
Posted 18 April 2021 - 12:42 PM
Recently fitted the thinner spacer. Not yet fitted the carb, but seems have a little more room.
#5 Moshtaraq
Moshtaraq
  • 86 posts
Posted 18 April 2021 - 12:51 PM
Let me know when you fit it.
#6 viz139
viz139
  • 674 posts
  • Local Club: Irish Mini Owners Club
Posted 18 April 2021 - 01:09 PM
The filter looks upside down. The choke holes in the filter backplate should line up with the choke holes on the carb.  There are several filters that will fit with either center or offset holes.
http://www.minispare...30.aspx|Back to
http://www.minispare...35.aspx|Back to
http://www.minispare...ir/56-9135.aspx
#7 tmsmini
tmsmini
  • 731 posts
  • Local Club: MOASF
Posted 18 April 2021 - 02:24 PM
Different manifolds have diiferent dimensions.
The CAM6618 is slightly shorter in that dimension.
https://www.theminif...inlet-manifold/
#8 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 18 April 2021 - 03:10 PM
Buy the E.R.A type adjustable top engine steady and tilt the engine forward slightly.
Phil.
#9 Moshtaraq
Moshtaraq
  • 86 posts
Posted 18 April 2021 - 03:34 PM
Phil.
I was considering that but I was thinking it would put strain on my silentblocks, wouldn't it?
#10 luismx123
luismx123
  • 525 posts
Posted 18 April 2021 - 04:11 PM
Hi again,
  • spacer
  • bracket
  • HIF44
  • cone filter
Thanks,
Jens
your filter is upside down as said above. the holes in the plate should be the lowest part
#11 Moshtaraq
Moshtaraq
  • 86 posts
Posted 18 April 2021 - 04:22 PM
Then the holes are drilled wrong in the filter plate, I bought it as a unit. I'll try that!
#12 Readers14
Readers14
  • 439 posts
Posted 01 May 2021 - 03:38 PM
Carb & MED filter fitted today. The thinner spacer gives you a bit more room to play with & the filter fits in nicely.
#13 Maccmike8
Maccmike8
  • 1,101 posts
Posted 01 May 2021 - 04:50 PM
How does it run, you a happy man?
#14 Moshtaraq
Moshtaraq
  • 86 posts
Posted 01 May 2021 - 04:53 PM
Fitted the filter right side up by the way and I only have a couple of millimeters clearance so I'm going to fit a thinner spacer. Still waiting on my order from minispares, 5 days and still not shipped.... very sad how they are getting worse throughout the years
Edited by Moshtaraq, 01 May 2021 - 04:55 PM.
#15 Readers14
Readers14
  • 439 posts
Posted 01 May 2021 - 05:42 PM
Haven’t fired it up yet. Battery is on charge.
Hoping to get it fired up tomorrow all being well.
Edited by Readers14, 01 May 2021 - 05:44 PM.
