Spi Inertia Switch Wiring
8 replies to this topic
#1 timmo
timmo
  • 156 posts
Posted 19 April 2021 - 03:05 PM
The wires to my inertia cut off switch on my project had been cut and joined together, guessing the switch was dodgy and they cut off the plug and joined the wires.
I've sourced a correct cut off switch with a plug and a couple of wire tails, but not from a mini and the wires are different colours to the original loom. Has anyone got a picture of the spi wires going to the pin outs on the switch plug so I can see where they are supposed to go please.
Added a pic of the plug I have, are the wires in the correct pinouts?
#2 Steve220
Steve220
  • 5,063 posts
  • Local Club: BMC
Posted 19 April 2021 - 10:25 PM
It won't matter which ones go where, it's a voltage in, voltage out to the pump.
#3 timmo
timmo
  • 156 posts
Posted 20 April 2021 - 06:17 AM
Thanks Steve, are the wires on the correct pin outs? So I take it the switch is just a "breaker" when you have a bump it just breaks the circuit until you reset it? Not used to this modern tech on a Mini, first SPi I've owned
#4 KTS
KTS
  • 2,454 posts
Posted 20 April 2021 - 07:39 AM
the middle pin on the inertia switch should connect to the power in terminal when the switch is tripped, so you can use that to work out which of the outer pins is power in and which is power out
as Steve points out though, if you're just using two connections, then it doesn't matter which way round they're connected
#5 timmo
timmo
  • 156 posts
Posted 20 April 2021 - 09:53 AM
so would the middle pin be used to light up a warning light on the dash? If used on a different make of car?
#6 KTS
KTS
  • 2,454 posts
Posted 20 April 2021 - 11:21 AM
that's what i've used it for, but could possibly have other uses (e.g unlock doors in a crash)
#7 brivinci
brivinci
  • 1,195 posts
Posted 21 April 2021 - 09:24 PM
Wow, that's an amazing idea! In the 15+ years and 25k miles I have down with my SPi, I have only had an issue with this switch once. I as driving through NYC and hit a MASSIVE pothole that triggered it. It was pretty obvious though. Massive bang from pothole and the car cut off. Still, not a bad idea to add an idiot light just to be safe.
#8 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 17 March 2024 - 07:24 PM
Hello.
What size / spec cable (wires) did you use from the new inertia switch back to the fuel pump?
#9 KTS
KTS
  • 2,454 posts
Posted 17 March 2024 - 08:35 PM
Hello.
i used 1mmthinwall, but that was for a facet fuel pump, not the SPI pump
Edited by KTS, 17 March 2024 - 08:39 PM.
