https://www.demon-tw...cB&gclsrc=aw.ds
I’ve drilled a hole within my exhaust system just below the rod change area where I’ve dropped the sensor cable through but not sure if this is correct or should be closer to engine ? I was due to have someone weld the o2 sensor bung for me this week.
Picture attached shows position of drilled hole and the end of this exhaust section goes onto the y piece.
91404DEA-4CC2-4766-A6B7-0FB136DD61FC.jpeg 172.04K
2 downloads
