Spin On Filter Head
Posted 03 May 2021 - 04:28 PM
(Tired of the canister....have a donor spin on head available)
Posted 03 May 2021 - 04:32 PM
Should just be a straight swap, I did the same on my car as I got annoyed with the canister and its tendency to make oil changes a messy affair! Pretty sure it's a paper gasket.
Posted 03 May 2021 - 04:36 PM
You will need to change the fixings. And get the correct gasket.
Posted 03 May 2021 - 04:40 PM
Here’s everything that you need https://www.morrismi...-filter-p830101 Minispares probably do the same kit.
Posted 03 May 2021 - 05:02 PM
So looks like have to swap the studs in too....good thing I have the donor attached to a block.
Posted 06 May 2021 - 06:59 PM
I've just twisted the pipe on the donor spin on one
Posted 06 May 2021 - 09:44 PM
Is the pipe from the block to filter head the same on both??
I used the same one when I changed mine over.
Posted 07 May 2021 - 04:51 AM
Pipe is indeed the same.
A little more time consuming than I thought.
The studs on the canister head are so long they must be removed with the head in place as the slam panel support is in the way.
Had to cut a new gasket using the tatterd remains of the old one.
Job done though..... rest in piece you pain in the arse canister filter.
I do like originality....but the filter head and filter are pretty well hidden.....my pipe is still engine green.
Posted 07 May 2021 - 07:38 PM
you can get a spin on head (older type) which uses the same studs. I got one when I swapped
Paul
