Hi all
I’m hoping someone can help me with an issue that has come on this week with my engine.. I will try to keep it as brief as possible but give as much information as I can
I have rebuilt my engine using all new internals except pistons con rods and rocker / valve setup (I did use new followers and springs etc.)
before starting the engine I checked oil pressure and on starter motor was between 50-75 psi
on first few starts oil pressure was good hovering around the same 50-75 psi range. While the engine was out the car I started it a few times with no issues and ran basically a float pot of fuel through maybe 10 or 15 times over the course of 4 weeks
then when my body came back from paint I installed subframes, engine, front seats, brakes etc. And plumbed up a fuel bottle so I could run for longer periods - to set ignition timing and heat the new exhaust
After running for 10-15 mins I noticed the oil pressure gauge was reading between 25 and 50 psi but didn’t think much of it as it was still running on idle warming up
I took the car for a run up a private road to check gear changes as this was first time I could check all gears since rebuild and everything seemed sweet and all gears selected ok - I then noticed that my oil pressure was 0 - no oil pressure showing on gauge at all so I shut the engine down and pushed her home
This was 4 days ago
just went to check oil pressure again - removed plugs and turned the engine on starter motor and there is 0 oil pressure
any advice why it all was going so well and now gone so badly would be appreciated
